Tool with Dragmenu is hard to select using Stylus #94324
Reference: blender/blender#94324
Operating system: Linux-5.15.0-2-amd64-x86_64-with-glibc2.32 64 Bits
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.86
Broken: version: 3.1.0 Alpha, branch: master, commit date: 2021-12-22 12:16, hash:
d6224db8f1
Worked: (long time ago if ever)
The tools in the tools panel on the left, which have mutliple tools assgined to on button, are really hard to select using a tablet. This is because they open the menu on a timer and on even tiny drag input. (The timer seems to interact strangely with the tooltip timer, causing it to open immediatly sometimes, but that is not part of this report). The drag threshold for detecting a drag seems to be not influenced by the settings in the preferences (#92995, #84726). Also the drag causes the selection to be canceled on release leaving it not selected, while on normal tool buttons it is finished on release, meaning they will be selected. That is IMO the real bug here.
I checked that the correct drag threshold is used by
WM_event_drag_threshold
on my device and it is! But the tool in the toolbar which is explicitly mentioned here seems to be not using it.Exact steps for others to reproduce the error
self explanatory, just drag the toolbar buttons and observe. Also play with the setting "Tablet/Mouse Drag Threshold" to see that it in fact doesn't change anything.
Added subscriber: @HDMaster84
Added subscribers: @lichtwerk, @iss
@HDMaster84 is this still an issue? don't have tablet to check here, but since you are involved with development, you can confirm reports. If you want somebody else to check, perhaps @lichtwerk can have a look.
This is still an issue. Tested version:
Broken: version: 3.2.0 Alpha, branch: master, commit date: 2022-02-02 12:12, hash:
e54fba5591
Here is a gif of it. Due to the framerate it looks a little more irregular than it really is.
Thanks for update, will confirm then
This problem does not require a tablet, it's just that with a tablet you can't really click and do no drag at all. You can easily reproduce this using your mouse.
On mouse over you mean? Not on my side, how is this done? Does not seem to beaffected by the
use_mouse_over_open
User Preference?Hm, also having trouble reproducing/understanding this
For me, it only works like this:
What am I doing wrong?
@lichtwerk When you press down your LMB, first it will make the tool light up blue, then after half a second the tool goes dark again and the popup with the options opens.
I would assume I am not the only one who wouldn't want to select the specific tool in the submenu every time I switch to it. So here is what I do:
The problem with that is, that the click needs to 1. be fast as there is a timer, 2. have no drag. Both conditions can make it difficult to select the tool on a tablet or sometimes even with a mouse. You can see the typical result in the gif that I posted.
Added subscriber: @hmelender
I can confirm this is an issue for mouse as well.
A drag and release over a tool bar button should always select the option where the release happened (assuming the release happened either on the button or the popup menu where the drag operation started).
It should not keep the currently active tool, because that would likely go against the intention of the user. You wouldn't click on a different toolbar button if you intended to keep using your current active tool, right?
Fix this behaviour and the bug should probably go away. Personally, I am still learning all the keyboard commands, so the mouse UI is very important to me.
Detailed steps on how to reproduce this:
