Cycles X cannot finish rendering a sequence #94383
Reference: blender/blender#94383
Graphics card: GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.89
32GB RAM
Broken: 3.0.0
Worked: 2.9.3
With Cycles X, the rendering gets stuck at random frames. It happens with any scene including the default scene.
I've updated the graphics card driver, tried reinstalling Blender, but they didn't work.
I brought down the sampling rate, turned off denoising etc which helped render more frames, but it always gets stuck before finishing all of it.
Looked into temp folder, but there was no error log.
I also tried using CUDA instead of OptiX, and also do CPU render, but they all get stuck at some point.
It doesn't seem it is using up all RAM or VRAM.
I think it's specific to my set up and don't think that it's possible to reproduce it for other people. But for me, render any scene with about 100 frames and the render view will freeze at some point and crash.
Debug output and system information after rendering default scene, crash after 14 frames, no crash log found.
blender_debug_output.txt
blender_system_info.txt
Added subscriber: @syn-crow
CrashLog.txt
This is the last bit of log when I start the Blender in Debug mode and let it render until it stops working.
Added subscriber: @Garek
Hi, thanks for the report. Does it happens with latest 3.1.0 alpha build?
https://builder.blender.org/download/daily/
Yes, it crashed on the second frame. For that one, I had the sampling to 100 and turned off the noise threshold, and had Optix Albedo Denoise.
Can you check if it's only Cycles, or EEVEE/Workbench is also affected?
For testing purposes it's better to simplify file as much as possible to rule out specific features. Using default scene is a good choice. While in default scene try
File
->Defaults
->Load Factory Settings
. That should rule out any non-standard add-ons.EEVEE and Workbench seem to work fine.
I loaded the default setting, but with Cycles it got stuck half way rendering the first frame and it stopped. And that's just a default scene with a cube with no animation whatsoever.
Can you run
blender_debug_gpu.cmd
and provide debug output along with crash log?blender_debug_output.txt
Here are the logs. It managed to render up to 14 frames and then it got stuck and stopped at 15. The scene was just a default cube with no animation. There was no crash log that I could see in the temp folder.
Thanks. I don't see anything strange in particular... Just a wild guess, check if your C drive have enough free space. When rendering Blender writes frames in
temp
folder on C drive.Meanwhile I'll tag it as unconfirmed since there is high chance it's computer configuration, also change status since information is provided and so others can take a look.
I don't think it's the disk space. I have about 700GB of free space in my C drive, but it's still freezing up.
As the last hail Mary, I updated to Windows 11, and that seems to have worked.
I loaded up my scene that it could never render completely and put the samples to 100 and used OpenImageDenoise.
I was able to render all frames.
Update: With Noise Threshold on, it still does crash, but at least it can render without it.
Thank you for looking into this Garek.
Now I am suspecting that it has something to do with the Render window. When I minimize that window, I can throw any denoiser settings at it (including Noise Threshold and Optix denoiser) and it can render the sequence no problem. It's only when I leave the window open, the render gets stuck.
Obviously now that I know there is a work-around to finish rendering, it's much less of a priority, but would be nice to know why this is happening at some point.
So does Blender crash or Render window closes? Now that I recall debug output I suspect the latter.
What happens with other render display types?
Keep User Window is the only one that works. For everything else, it just crashes after a few frames (I have all the denoising on).
When it crashes, it just stops in the middle of sampling and goes silent. When I click on the window, it just says Blender stopped responding and the window turns pale white.
This would be the same if I start rendering with the window minimized and then click on the window to enlarge it. At that point, after rendering a few more frames and it freezes.
Added subscriber: @iss
@syn-crow Can you upload sample file? This looks like valid issue, but without sample file I don't think I will be able to reproduce. Also did you check any later development versions?
It's not scene specific. I can just open Blender with default scene, change to Cycles and hit render right away, and it will still crash if I have render view opened.
I will try the 3.1 beta and let you know.
Thanks for update, that I definitely can't reproduce. Also did not see request to try updating GPU drivers, can you check of that helps too?
