Crash in nvoglv64.dll entering edit mode on curve #94454
6 Participants
Reference: blender/blender#94454
Graphics card: NVIDIA GeForce RTX 3080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.39
Broken: version: 3.1.0 Alpha, branch: master, commit date: 2021-12-26 20:08, hash:
20b438d523
Worked: 2.93 LTS
Caused by
eb0eb54d96
Blender crashes with an access violation in nvoglv64.dll when entering edit mode on a curve with the following script running. This worked fine in Blender 2.93 et al, so something has changed with object.to_mesh() that nvoglv64.dll does not like.
See the attached blend file, and run the embedded minimum repro
crash_script
text file- which is a simple GL handler that should use blf to display the number of mesh polygons in a curve.the repro script, for posterity:
edit: apparently the blend file did not attach, here it is again
crash.blend
You can get around it passing the evaluated object to
to_mesh
, see:crash_corrected.blend
Added subscriber: @testure
Added subscriber: @schampions
This comment was removed by @schampions
Added subscriber: @lichtwerk
Can confirm, will check
Caused by
eb0eb54d96
to_mesh
It is not totally obvious for me why this crashes (passing the non-evaluated curve) and the commit message would imply this is not generally a problem:
So, I would still like @HooglyBoogly to take a look (it is just not nice to have working [in 2.93] scripts resulting in a crash all of a sudden without explanation somewhere -- even if 3.0 is a compatibility breaking release)
It is also not mentioned in [if it would be an expected breaking change] https://wiki.blender.org/wiki/Reference/Release_Notes/3.0/Python_API
Unfortunately I can't reproduce this at the moment:
{F12780516 size=full}
Maybe I'm missing something?
Is this
crash.blend
? orcrash_corrected.blend
?Are you mouse-selecting points in editmode?
Have you done extrusion prior?
Oops! Apparently I was using
. I can reproduce it now. I'll look into this.I've found the fix, it was a relatively simple mistake in
eb0eb54d96
. However, based on the code there I would strongly recommend you use @lichtwerk's corrected version that uses a depsgraph to get the actual evaluated mesh (or a copy of it anyway).This issue was referenced by
50c39ff8fe
c0fdf16561
