Export DXF add-on not working #94484
Closed
opened 2021-12-30 04:28:41 +01:00 by fryc · 7 comments
After click export as DXF files, no files can be found in my computer. I tried both mesh lines and curves, also some different set-ups. Still not a single file was created.
Export curves as DXF format in Blender 3.0
system info etc.txt
**Short description of error** After click export as DXF files, no files can be found in my computer. I tried both mesh lines and curves, also some different set-ups. Still not a single file was created. **Exact steps for others to reproduce the error** Export curves as DXF format in Blender 3.0 [system info etc.txt](https://archive.blender.org/developer/F12781407/system_info_etc.txt)
Author
Added subscriber: @fryc
Added subscriber: @chemicalcrux
It looks like that, by default, it tries to name the file ".dxf". If you save without changing that name, it will wind up being a hidden file on MacOS and Linux.
Perhaps that's what is happening? I cannot reproduce this otherwise on MacOS.
It looks like that, by default, it tries to name the file ".dxf". If you save without changing that name, it will wind up being a hidden file on MacOS and Linux. Perhaps that's what is happening? I cannot reproduce this otherwise on MacOS.
Added subscriber: @rjg
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
Reference: blender/blender-addons#94484
