Grease pencil layer issue #94487
Reference: blender/blender#94487
Graphics card: Intel(R) HD Graphics 530 Intel 4.5.0 - Build 27.20.100.8681
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash:
f1cca30557
Using the draw mode right-click to delete layer of drawing, the problem is that the layer is still visible on the list of layers and having it selected will not show any effects while you draw
Added subscriber: @jrodenf
Added subscriber: @chemicalcrux
I am unsure how to reproduce this issue on 3.0.0.
I spawned a Stroke object and went into Draw mode. I right-clicked and deleted the Lines layer, then drew some more before right-clicking and deleting the Colors layer. At that point, there were no layers left, and I could not draw. All of this seems correct to me.
Please update the task with specific, step-by-step instructions to reproduce the problem.
It's probably just my computer, but in my case the window on the right (in Blender) where the box with the list of layers is located, still shows the original layer which is selected by default, it's rather misleading to think that you can still draw, but nothing happens.
I see two places where the layers are listed. One is in the Properties menu:
The other is in the 3D viewport, up here:
Which one are you referring to (or is it in another place)? Both appear to be updating correctly when I delete a layer.
If it's one of those two, please try loading factory-default preferences (Edit > Preferences, then check the menu in the bottom-left corner for a "Load Factory Preferences" option)
See the image below:
If I delete the layer like this:
I get this, where the layer is not present:
But after using the mouse to draw, I get this:
And, the layer is automatically selected; however, if I try to draw, no stroke appears.
Added subscriber: @antoniov
When you draw again, the layer is created automatically. I guess you don't see a stroke because you haven't the
Autokey
enabled. You have two options: a) Create the frame manually usingI
key menu or b) EnableAutokey
Thanks.
