Normals generated by Curve to Points node aren't always perpendicular to the curve #94522
Reference: blender/blender#94522
Graphics card: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 497.09
Broken: version: 3.1.0 Alpha, branch: master, commit date: 2021-12-26 20:08, hash:
20b438d523
For curves with sharp corners, like poly splines or bezier splines with vector handles, the normals are not perpendicular to the straight curve segments, but bend around corners. This makes it impossible to properly align instances to the curve.
Added subscriber: @slowburn
Please provide the .blend file to make it easier for us to reproduce the problem.
What's probably happening here is that the normal is interpolated between the control points. To work around this you could resample the curve to a poly spline that does not have intermediate points.
Here's the file. As you can see it happens with Poly splines as well.
And you're right, there's some interpolation going on, I'm just not sure if it's intentional. According to the manual, Curve to Points node should return a proper normal at each generated point instead of some interpolated value from the control points. Or at least there should be a way to control when this interpolation happens.
curve_normals.blend
One workaround I found is to scale the control handles to 0, but it doesn't eliminate the problem completely. And it would be nice to have a proper fix anyway.
2022-01-10_20-13-37.mp4
I guess a fix is to make a different version of of the interpolation of attributes to evaluated points, but I think there are multiple use cases here.
Or maybe it would make sense to require having a higher resolution curve for the second case, and always avoid interpolation.
To change this, I think the sample curve node and the curve to points node would have to be refactored. We might also have to redefine the tangents as the direction vector from one evaluated point to the next (which might make sense anyway, since we decided that a point attribute value conceptually applies to the following edge).
Since the solution isn't obvious and would have to be discussed, I think this is more of a design task.
