Library weak reference generates "path not found" errors when appending #94805
legacy module
legacy module
legacy module
Eevee & Viewport
legacy module
legacy module
legacy module
Rendering & Cycles
legacy module
legacy module
legacy project
2.81
legacy project
legacy project
BF Blender: 2.8
legacy project
BF Blender: After Release
legacy project
BF Blender: Next
legacy project
legacy project
legacy project
legacy project
legacy project
legacy project
legacy project
Platform: Windows
legacy project
legacy project
legacy project
Priority::Normal
Status::Archived
Status::Duplicate
Status::Resolved
Type::Bug
Type::Patch
Type::Report
8 Participants
Reference: archive/blender-file#94805
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.84
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash:
blender/blender@f1cca30557
(tested also on latest 3.0.1 Release Candidate)Worked: none
Library weak reference seems to be set on appending, but not pruned afterwards.
There is no way to remove this information from the file within Blender (I tried all possible cleaning functions + making path relative), nor with Python (Library weak reference is read-only), and it will always generate "path not found" errors.
Report Missing Files
operator ({nav File > External Data > Report Missing Files})The error "path not found" for "File 2" will appear
untitled2.blend
Added subscriber: @Mustard
Added subscriber: @mano-wii
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
I can confirm the problem.
The value in
id->library_weak_reference->library_filepath
of "MECube.001" points to a path that no longer exists.But I'm not sure if this is a bug. This value seems to be a utility "to allow re-using already appended data in some cases, instead of appending it again".
But for me it's a little strange that this value is saved in the file. It seems too weak to be saved with the file (and may increase its size minimally).
Added subscriber: @mont29
It's saved in file to allow re-using same data on future append, even across editing sessions.
Should be ignored by 'missing paths' report though. will check on that.
Thank you for your answer (and your work in general)!
May I suggest the possibility to be able to prune these settings in some way, maybe through the already available cleaning functions? These references might become useless for instance if you share the file with other people (especially if they are saved as absolute paths).
In fact it is strange that once I append something, I am not able to clean these values in any way.
Not sure this would be much useful to be honest, this info is supposed to fully internal currently, and invisible for the user...
We may go beyond in the future when it gets more used/exposed to the end user, but don't think it would be that useful currently to add more tools on it.
This issue was referenced by blender/blender@08822801ac
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
Added subscriber: @sharpened
@mont29 's commit fixes "path not found" reports for
however I am running into a related issue reporting console warnings if I run
Warnings state: !!Warning: Path '\some_path.some_blend.blend' cannot be made relative!!
These warnings are fine and do not disrupt normal workflow, but I agree with @Mustard
In my case, after appending files I do not need this weak reference, and they are in fact useless paths if the .blend is moved to another computer or the file which was targeted for the append no longer exists.
Although this is not exposed to the user outside of the console or data API, my worry is exposing personal file structure (or more importantly company-sensitive file structure) when publicly sharing a .blend
I would suggest adding the same fix into the 'make paths relative' functionality - but this does not fix my issue above
maybe allowing these paths to be writable in certain circumstances
maybe adding functionality to clear these paths in "Clean Up > Unused Data-Blocks" since they are in fact unused (but I guess are not data-blocks by definition)
maybe adding a button to "Clean Up" called "Unused Library Weak References"
Added subscriber: @Vyach
Encountered the same. It is just annoying and confuse me as user, makes me feel something wrong.
I want to have clean and squiky file, that I can pass to customer or other worker without questions «what files are missing and why?»
So yes, please, make it deletable or cleanable at least.
There shouldn
t be garbage, that I can
t find clean, at least manually.I also confirm the issue.
Maybe you can boost the visibility of the problem creating a new Task?
Added subscriber: @DarioDaF
