Tilt works strangely in a poly curve (or other type with U resolution of 1) with only two control points #94837
Reference: blender/blender#94837
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 3.1.0 Alpha, branch: master, commit date: 2022-01-06 23:21, hash:
e6ca0b33e9
Curve tilt works strangely if the curve is a straight line with two control points.
I attached a gif animation.
It looks that tilt for first control point does not work, and tilt for second control point is used for first one.
If the curve is extended to three or more control points, tilt works well.
Make a curve object with two control points.
Set spline type to Poly, and make it as a simple line.
Set bevel depth parameter >0.
For clarity, make wireframe ON in viewport display.
Set tilt for first control point to 0.
Set tilt for second control point to not 0 value.
The curve should be a twisted cylinder, but it just rotates with tilt value of second control point.
(It looks that tilt of first control point is not used, and second one is used)
#94837.blend
Note that geometry nodes behaves better here:
T94837_geonodes.blend
Added subscriber: @popqjp
Added subscriber: @lichtwerk
Can confirm, will check.
Note that geometry nodes behaves better here (probably because these are not poly curves internally?:
Tilt works strangely in a curve with only two control pointsto Tilt works strangely in a poly curve with only two control pointsTilt works strangely in a poly curve with only two control pointsto Tilt works strangely in a poly curve (or other type with U resolution of 1) with only two control pointsThis issue was referenced by
a6d70eecf4
fb21201d42
c8e536bac3
