Custom bone shape disappears if going to editmode on the custom shape object #94886
Reference: blender/blender#94886
Operating system: Windows 10
Graphics card: RTX 2070 GAMING OC
Broken: (example: 2.80,
edbf15d3c0
, master, 2018-11-28, as found on the splash screen)3.0+ is broken or altered
2.9- old function works
Caused by
594656e7a3
#94886.blend
Circle
objectOriginal Report
note that the original file may crash on load due to #94726 (Segfault with GPU subdivision on a custom bone shape)
After I add a circle object to a shoulder bone, I'm going into edit mode for the circle object so that I can edit the custom bone shape.
But the custom bone shape disappears.
All of the other bones remain it's just when I go into edit mode for the object that the bone uses for its custom shape. Before 3.0 you could see both the bone and the custom shape you were using so that you could easily edit the object to position the bone in real-time. This seems to be broken now or possibly altered? Seems more like a bug since the only solution I've found on blenderartist is to use the navigation panel in the bone tab under the viewport display. This makes positioning and editing custom bones extremely tedious as compared to just moving around the custom object in edit mode to place your custom bone.
Attach circle as a custom object for the bone, then while in object mode select the circle object. Then enter edit mode for circle object and the custom bone disappears, in my supplied blend file the head, neck, left shoulder, and left arm have these. Under the shapes collection if you go into edit mode for any of the objects the corresponding bone will disappear. (FK bones with edited shapes will be on by default but they live in layer 2 of the skeleton)Rigging LEARNING.blend
Added subscriber: @Steven-Baar
Added subscriber: @lichtwerk
Can confirm, will check
Caused by
594656e7a3
note that the original file may crash on load due to #94726 (Segfault with GPU subdivision on a custom bone shape), but can be reproduced in a much simpler file:
#94886.blend
CC @HooglyBoogly
Custom bone objectto Custom bone shape disappears if going to editmode on the custom shape objectThanks for the report. Unfortunately I don't have a great idea for how to solve this. Like I mentioned in that commit and
a07089dcb1
, I think the way this bone custom overlay works is quite bad and will necessitate hack after hack to keep things working as expected. Even before that change, the system didn't work with instances, for example.Converting this to use the existing instancing system should handle all of this complexity automatically. I think the only thing we'd need to add is a "viewport only" flag for instances.
However, I don't foresee myself having the time to do that soon-- I already have plans for more refactoring in other areas.
BKE_object_get_evaluated_mesh
just returns null when the object is in edit mode, so the existing code finds no mesh to draw.The following change makes this work in another hacky way by retrieving the original mesh if there is no evaluated mesh. I don't like the change enough to propose it in a patch, though if someone things this is important enough to add another hack for, I can do that.
Added subscriber: @dr.sybren
@dr.sybren: thoughts?
Once D13824 is committed, this situation might be a bit better / this might work. I still think using the instancing system would be better though.
I agree that this is the way to do things, having to go back & forth between different modes just to see what you're doing is quite the regression.
@HooglyBoogly now that D13824 has landed, do you think you could have time to find a nicer-than-the-above-hack solution for this?
Well, testing this now, the situation described in the report works. (I can go into edit mode on the custom bone shape mesh and see the changes on the bone's custom shape).
I wouldn't be surprised if we end up getting other bug reports relating to this situation. But, like I've said before on these tasks and commits, the way it works is just not ideal and misaligned with the way Blender works in other respects.
Thank you guys for your hard work!!!
