Cycles crash at the end of the render #95025
5 Participants
Reference: blender/blender#95025
Operating system: windows 11
Graphics card: GTX 1070 ti
Broken: 3.0
Worked: 2.93.7
Almost always, when I render, missing few samples to finish the cycles crashes. Usually when 4 to 6 samples are missing from the end.
The crash is random and I can't reproduce the exact steps. All I know is that the crash only happens a few steps before denoising.
I don't know if it may be some configuration that I have to do in windows because of the video card.
I look forward to some help. Thanks
Added subscriber: @Leejunfan
Added subscriber: @iss
Please download latest alpha build from https://builder.blender.org/download/daily/ and check if issue persists. To provide more info run file
blender_debug_log.cmd
and after crash upload created files.Hello, I did the debug test in Blender 3.0 and I had the crash. Follow the files.
progressiva 3d.crash.txt
blender_system_info.txt
blender_debug_output.txt
I got a file that doesn't render, it crashes at 121 samples, I tested it on 3.0 and 3.1 and the crash is on both. On 2.93 it works fine.progressiva 3d_bug.blend
Added subscriber: @Wovchick
There was crash file created
C:\Users\conta\AppData\Local\Temp\progressiva 3d.crash.txt
, please upload it here as well.Does this happen when you run file
blender_factory_startup.cmd
? I was able to render image without any issues.I tried again here and it still didn't work.
Thanks for checking, Crash file did not contain any useful information really. Also I see your GPU drivers are relatively recent, but perhaps updating these may resolve this issue. It would help to also check if this issue happens with certain renderer settings only like denoising for example.
Unfortunately I don't think I would be able to reproduce this issue and don't see other developers with similar system configuration I could ask.
I'll test some options here and get in touch if it solves.
What is the best driver for my 1070 to work well in Blender? Game Ready or Studio Ready?
I am not aware if either is preferred, both should work. Not sure exactly how these work in Nvidia. I think in AMD studio drivers or equivalent to that were basically older game ready drivers with some tweaks perhaps. I would reffer to what manufacturer says about what the difference is and recommendation.
Added subscriber: @Garek
To note, debug output says that it rendered 128 samples, it seems like it crashes while denoising. You can disable it to make sure it's that.
Additionally try to use latest 3.1.0 since it got fix for a similar problem
f179637222
And also you can use OptiX since as far as I see it you used OIDN to denoise.
Added subscriber: @mano-wii
Thanks for the report. Unfortunately the scenario described is too time consuming for us to track down, we require the bug reporter to narrow down the problem.
Rendering 121 (or 128) frames with the possibility of not replicating the problem doesn't seem like a good use of time.
While this is a real issue, it is only happening to a few people so far and it is not clear whether it's a solvable problem from Blender side...
So if you can simplify the file even further and figure out which setting is causing the crash, that would be appreciated.
I followed these guidelines here and it looks like the issue is resolved in 3.1
Changed status from 'Needs User Info' to: 'Resolved'
Good to know the issue is resolved.
If the problem persists, please let us know so we can re-open the report.
Don't forget to mention the specific version you tested again.
