WITH_GPU_SHADER_BUILDER doesn't work on Mac due to linking errors.
Confirmed, LowPublicTO DO
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from Developers.Mar 10 2022, 10:30 AM
@Jeroen Bakker (jbakker) is this an EEVEE & Viewport internal TODO?
If this should pass the Triaging queue, it would be better to tag BF Blender also.
If this should not pass the Triaging queue, it would be better to set subtype to TODO/DESIGN/... (default is REPORT which is associated with Triaging ) or set status to CONFIRMED
Clément Foucault (fclem) changed the task status from Needs Information from Developers to Confirmed.Apr 12 2022, 9:31 AM
Clément Foucault (fclem) triaged this task as Low priority.
Clément Foucault (fclem) changed the subtype of this task from "Report" to "To Do".
The situation was partially solved by rB664eb1936946 but there are a lot of linker warnings remaining.
