Texture margin generation Adjacent faces - border lookup fails in some directions around 45 degrees. #95249
6 Participants
Reference: blender/blender#95249
Broken version: Blender 3.1 alpha
60bd6804db
Last Working Version: This is new code which wasn't available in previous versions.
When having multiple adjacent UV edges with angles between ~30 and ~60 degrees next to each other, some parts of the generated margin are not copied from th correct face. Also the outer edge of the margin is very jagged.
patch:
https://developer.blender.org/D13935
steps to reproduce.
Added subscriber: @Baardaap
Added subscriber: @mont29
Changed status from 'Confirmed' to: 'Needs User Info'
This report does not contain all the requested information, which is required for us to investigate the issue.
Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
@mont29 Is there another way I should create a task for myself than report a bug and claim it myself? I don't see a 'create task ' option in Maniphest...
added patch
Removed subscriber: @HooglyBoogly
@Baardaap Ah sorry, did not realize that this was a task for a patch you were working on yourself. But even then, adding a decent amount of info (reproducible steps and file, proper module tags, and so on) is still a better idea, one-liner tasks do not help anybody else to understand what is going on here.
@mont29 Is there a way I can mark a task as ' for myself'? I really only created the task to have it show up on the list of pre-3.1 things. The explanation of what it's about is written up a lot more clear on the associated diff. It feels a bit like busy-work to recreate all than info over here?
The whole creation of these tasks was probably overkill. But that's because with my sleepy head I had read the schedule as bcon4 on feb 2 instead of march 2. :-D
Had I read it correctly I wouldn't even have bothered to create the tasks. Or probably only created them in the same moment as uploading the diffs.
This is generally not a good idea to 'just' have place-holder tasks like that. Either create a proper complete report, or just only do the diff (but would always recommend to have a proper report with all required info).
In any case, assigning yourself to the task is the proper thing to do - but regular users also do that quite often by mistake or otherwise, so when triaging this is not a reliable info unless the triager actually knows the person who did the report is a dev. Would suggest to at least leave a comment (or note in the task itself) making it clear you are on top of it then.
Added subscriber: @lichtwerk
Same as #95250 (Texture border generation. Adjacent faces uses stale UV map when in edit mode.)
Ok. I'll try to flesh out the reports a bit more this evening.
Will do!
This issue was referenced by
83fa6a1b2a
c8c9965df2
