"Fix T92953: Tool Settings: Drag on Tweak fails with LMB select" overrides default keymap entries #95349
Reference: blender/blender#95349
Graphics card: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 497.29
Broken: version: 3.2.0 Alpha, branch: master, commit date: 2022-01-30 06:07, hash:
a58592885c
The fix #92953: Tool Settings: Drag on Tweak fails with LMB select has some unwanted side effects. It overrides the regular entry. This is especially of interest for custom keymaps where you have modified the parts in question. Which happend to me. I couldn't explain why my keymap has quit working in the way i had it set up until i had a look at this patch.
What we have here with this fix is now two entries where formerly just one existed. And the fallback entry always overrides the regular entry. Instead of just showing up when you are in fallback mode.
SHA-1:
f1a488d0f2
Second screenshot to show that it is the Blender keymap with the factory defaults: And to show that the fallback entries shows in the factory defaults.
Added a video with further explanation. It explains the problem with the tweak tool in the 3d view, which has now also a legacy keymap item. Also here, factory defaults and Blender keymap.
2022-02-02 07-50-31.mp4
Added subscriber: @tiles
#95350 was marked as duplicate of this issue
Ah, accidentally created the task twice. Sorry for double post -.-
https://developer.blender.org/T95350
Added subscriber: @mano-wii
This is what I see with LMB select's default settings.
So I assume the keymap needs to be customized, right?
No. The shot from above is a new compiled version from sunday, with factory settings and the default keymap. As you can see, it shows the legacy entries below the regular entries. And these legacy entries overrides the regular ones.
I have added a second screenshot.
Ooops, I swapped LBM selection for RBM.
I tested it and indeed it looks confusing.
There are three places for setting the "uv.select" shortcut:
{nav Image > UV Editor > Image Editor Tool: UV, Tweak (fallback) > Select}
The 1st shortcut I don't know what it's used for. Is this the so-called "regular entry"?
The tools shortcuts work correctly.
To test the 2nd, I changed the shortcuts of the "Tweak" selection tool, and, with the tool activated, the shortcuts worked correctly.
To test the "Tweak (fallback)", in the 3D View I set the selection fallback to "Tweak" and in the UV editor I activated any non-selection tool. The shortcut worked as expected.
I'm not sure what you mean by "legacy entry" and "regular entry". Can you elaborate?
With legacy i mean the keymap items with the (fallback) in the description.
Number two and three are the trouble makers. The fallback keymap entry number three overrides the one from number two.
It should be one entry visible at time. Either you are in regular mode. Or you are in fallback mode. This is what the fallback entry was added for in the code:
if (fallback and (params.select_mouse == 'RIGHTMOUSE') ...
But it shows also with lmb select. And overrides the not fallback entry. Since you have now two similar entries that does the same. As it currently is you have to edit the fallback entry. Since the fallback entry overrides the regular entry. The regular entry is the one that existed before the patch already.
I will have a look to make a video to make the problem even more clear.
I have to admit that i am not able to reproduce the problem in a clear manner anymore. Now the trouble maker works fine with the Blender default keymap.
But it still fails in my custom keymap. I need a bit more time here to investigate further. I can for sure say that reverting the patch solved my issues with my custom keymap. I am just not able to really nail it down at the moment. Please be patient.
Found a way. In the added video i demonstrate the problem with the tweak tool in 3D view, which now also has a fallback entry in the keymap.
One last thought regarding custom keymaps. The fallback entry imho shouldn't show there at all, and should not affect anything. Since with custom keymaps you cannot adjust the parameters from the Blender default keymap. There is no way to switch between left and right click select with a custom keymap.
I just realized that the fallback entry is much older. It existed before the patch already. And so the problem is much older too. It's just, up to this patch i had no overriding problem with deselect on nothing.
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Added subscriber: @ideasman42
Watching the video, there is a mistake when testing the shortcut of the
3D View Tool: Tweak
... this shortcut only works if the Tweak tool is activated. In the video you activated another tool so the fallback shortcut is used.But I don't understand why disabling the
3D View Tool: Tweak (fallback)
keyitem makes the3D View Tool: Tweak
shortcut work (in my opinion the {nav 3D View (Global) > Select } is what should be used instead).Not sure if this is a bug, it looks more like a problem due to lack of documentation explaining it.
@ideasman42, you should understand better what is happening here, is there a bug?
The report description needs to be updated indicating the 3 existing shortcuts and what happens when disabling the fallback.
Yes, as told i had some troubles to make a use case with the Blender keymap where the overriding behaviour shows. The case in the video is reproduceable. And is exactly the trouble that i have with my custom keymap. The deselect on Nothing part has quit working. I have it off. But the fallback key item has it on. And overrides my change.
I hope the behaviour is now clear enough to follow further what is going on here.
For me it is definitely a bug since changing one setting in the one key item overrides the other key item. Which should not happen. I should not be required to change a setting in another key item to change the current key item.
I didn't see anything overwriting another key item.
As mentioned, the "fallback" key item is used when the selection tool (the first in the tool list) is NOT activated.
It is not overriding the selection tool's key item.
It would only be overridden if, even with the selection tool activated, the fallback key item is still used.
But the "deselect on nothing" setting is in fact overwritten by the fallback tool. You have it twice in use. Else the behaviour would not change as shown. I have now to turn off the Deselect on nothing in two keymap items to get the move tool working in the way it was set up. And this tweak tool is just one of the fallback tools, one example. There are more.
Well, you already mentioned it, it is already odd that changing the tweak tool behaviour changes the behaviour of the move tool. But i am far away from understanding the keymap design anyways. I can just report what i find.
As told, my custom keymap has quit working regarding the "Deselect on Nothing" behaviour after this patch. I am still under the impression that this is a bug after looking at what causes it. And so i have reported it. It is of course your decision if you fix/change the trouble maker or not.
Many thanks for your patience.
Thanks for the information, in fact I was able to identify the problem and created a report detailing it:
#95452 (Multiple calls of 'view3d.select' with LMB selection keymap)
Closed as duplicate of #95452
Excellent. Many thanks :)
