Using the data structure from T95355 should provide a performance benefit to all of these nodes, allowing them to be used in cases where there are many more splines/curves.
- Curve Length rB400ea40dca7a
- Curve to Mesh rB7484f274dcdc
- Curve to Points
- Fill Curve rBb2cb99d3fd19
- Fillet Curve rB2551cf908732
- Resample Curve rB60a6fbf5b599
- Reverse Curve rB298d8a7b4aed
- Sample Curve rB6bcda04d1f1c
- Subdivide Curve rB9435ee8c6519
- Trim Curve D14481
- Input nodes
- Curve Handle Positions rB9ec12c26f16e
- Curve Tangent rBceed37fc5cbb
- Curve Tilt rB9ec12c26f16e
- Endpoint Selection rB471f27d66bd7
- Handle Type Selection rB578c2f117a9e
- Is Spline Cyclic rB9ec12c26f16e
- Curve Length rB62334c6ee4c9
- Curve Parameter rBf4f89a76a8f4
- Curve Resolution rB9ec12c26f16e
- Normal rBceed37fc5cbb
- Set Curve Radius rB9ec12c26f16e
- Set Curve Tilt rB9ec12c26f16e
- Set Handle Positions rB00ba51d37bf5
- Set Handle Type rB00ba51d37bf5
- Set Spline Cyclic rB9ec12c26f16e
- Set Spline Resolution rBddf956fb5846
- Set Spline Type rB9e393fc2f125
- Primitive Nodes
- Arc rB444d57d44045
- Bezier Segment rB389807624de8
- Circle rB444d57d44045
- Line rB444d57d44045
- Spiral rB444d57d44045
- Quadratic Bezier rB444d57d44045
- Quadrilateral rB444d57d44045
- Star rB444d57d44045
- Mesh to Curve rB901a03725ed5
- Realize Instances/Join Geometry rB6c6f591f909a
- Duplicate Elements rB663bd38ed65e
- Convex Hull rBd4bd9f6a278b
- Transform rB5d7f4f2cab20
- Delete Geometry rB8a6cbcf386a1
- Bounding Box rB8589f60546b3
- String to Curves rBa646a4b47e4c
