Geometry Nodes: Unusable texture inputs? #95461
7 Participants
Reference: blender/blender#95461
Operating system: Biological Bobsleigh Birds (Linux)
Broken: 3.0, 3.20 alpha
As the Attribute Sample Texture Node is being removed, it doesn't appear that there is any way to use the Texture socket types that can be exposed from the modifier panel anymore:
Texture socket type added w/ Attribute Sample Texture:
https://developer.blender.org/D11222
Exposed as nodegroup input in modifier panel:
https://developer.blender.org/rB3025c348253a66f9c316259aa03f8884bf56d779
Two possible solutions:
Add Texture Sample Field node.
Make texture input output RGB.
Added subscriber: @WCN
Added subscriber: @iss
This sounds like design issue rather than bug to me. If I understand this, you say, that Attribute Sample Texture was only node that could work with textures, but now there is none (non-legacy)?
Added subscriber: @Rawalanche
The node you are talking about has been replaced with Image Texture node:
Which is not planned to be deprecated. Use that one, and use your texture input attribute as its input.
I think we'll end up removing the texture socket completely when we remove the legacy nodes "before 4.0".
The "problem" here is that it still shows up in a few places-- the group inputs and outputs list, and the switch node.
We could hide it from this list fairly easily, but I'm not sure it's worth it:
Personally I would be disappointed at losing the ability to reuse the same nodegroup with different procedural/volumetric textures chosen in the modifier pane.
Added subscriber: @Quver
Please don't! This is a very usable feature for reusable nodegroups and removing it completely is a step back to me.
Shaders currently lack this. Instead expand this functionality to shader nodes.
See
https://devtalk.blender.org/t/input-socket-for-image-texture-shader-node/19601
The current "Image Texture" node is primarily what does texture sampling and mapping. It doesn't really conflate it, because the texture data block is actually exposed as a node socket input. The only issue here is that right now, this data block can only be exposed at the Geometry Nodes Group Input UI. It can not be crated within the tree in the same way you can create a float, vector and so on.
So all that would be needed would be some sort of "Texture" input node with just image texture datablock selector, which would accompany this set of input nodes:
This would make things such as triplanar displacement mapping a bit easier to do, without user having to swap image datablock manually in 3 separate "texture sampler" nodes.
The video in the thread you linked to talks exactly about that. So I would not conflate ability to use image texture as a data type in GN with the ability to use legacy procedural textures.
To wrap it up:
The issue is that those procedural textures are legacy remnants of Blender Internal renderer. That doesn't mean you should not have the option to swap the procedural textures at your will. There are two more GN based concepts:
While the option 1. can feel less usable because it requires you to open a GN editor first before you can start switching and tweaking the textures, you must not forget the extreme amount of possibilities this opens. For example with the legacy textures, just mere mixing of them becomes a hell, requiring you to use multiple GN modifiers with the same GN node network, with one texture each. That's bad for both usability and performance. Let alone something like distorting the mapping of one procedural texture with another. That's pretty much impossible.
On the other hand, with GN it becomes trivial:
https://www.youtube.com/watch?v=4X4V-UUnYkM
So you trade a small reduction in ease of use by having to open node editor first to start switching texture types for giant increase in flexibility, by ability to mix, distort, blend, color correct, remap, etc... multiple procedural textures in a ways that were absolutely impossible with the legacy texture datablocks. I mean even XYZ offsetting of the texture mapping coordinates is not possible with the legacy textures, so you get whatever random seed you are stuck with, with very little option to art direct the initial state of the texture mapping.
Oh, turns out there are separate "texture" sockets and the "image" sockets. I'm sorry, I thought there is only one "purple" socket type that is used for any textures (both BI and image textures). I was worried about the "Image" socket being removed.
It's not a bug. The texture data block socket is deprecated currently. We do plan to have a new system to support sharing textures between different systems, the design for that is still being worked on.
Added subscriber: @Boris-Okunskiy
Can you please provide some pointers into the new texture sharing system (i.e. links to design documents, drafts, discussions, etc)? TIA
https://code.blender.org/2022/02/layered-textures-design/
https://devtalk.blender.org/t/layered-textures-design-feedback/23092
