Prototype for Node Layers / Modifier Tree #95472
13 Participants
Reference: blender/blender#95472
I worked on a little prototype for a layered view on a node group which could replace the current modifier stack. This is not a full design but a starting point to get an idea for how this kind of system could work.
The prototype is implemented as an addon that can be downloaded here: https://github.com/JacquesLucke/node_layers_prototype.
The prototypes adds an hierarchical view on a geometry node group in the properties editor. It allows adding, removing and changing nodes without using the node editor. Typically, a user would either use the node editor or this layered view depending on the required complexity. The basic idea is similar to how a material node tree is displayed in the properties editor. The main difference is that this new layered view is much more compact and the settings are in a separate panel. This more compact format makes it more suitable for more complex setups as long as not much nesting is required.
2022-02-03 15-31-59.mp4
I'm also wondering if the same layered view could be used for "layered texture painting" (and possibly other use cases as well). That's a bit harder to prototype right now, but currently I imagine it like so:
diffuse
,roughness
, ...).Mix Images
node that mixes two images based on some mask. Passes on both images which have the same name are mixed as well.Mix Images
nodes can be chained to mix different "pbr materials".I haven't really thought all that through, and don't have much experience with texture paining anyway, but it seems doable.
Node Layers Prototypeto Prototype for Node Layers / Modifier TreeAdded subscriber: @HooglyBoogly
Added subscriber: @guitargeek
Added subscriber: @mod_moder
Added subscriber: @Rawalanche
I like the idea as a means of deprecating the current modifiers. At the same time, I am not sure how well it would work to make GN more accessible to people unfamiliar with node based workflows.
One idea could be to make only specific higher level nodes accessible from this UI. This would also mean that custom node groups should receive some UI flag for the authors to determine of the node groups they made are "high level" enough to appear in this restricted list of nodes available from the Node Layer stack. But this would come with some obvious drawbacks.
The other idea would be to allow any nodes to be used through this UI. But this would mean that it would not be much of a benefit for new users because they would get overwhelmed by the sheer amount of available nodes, and eventually, they'd learn it as just an inferior way of putting together GN node networks. Also, I am not sure how this system would accommodate for the situations where node network branches out and then branches back together. Such situations are difficult to express in vertical layer stack.
If the plan is to eventually remove the current (in the future legacy) modifiers, then I am all for it. I am just not sure whether it's better idea to restrict these Node layers just to some pre-made GN networks emulating the old modifiers, to provide familiar workflow to users used to current modifier stack, or if to overwhelm them with the complete set of possibilities GN offers, with the UI system which doesn't accommodate for those possibilities well.
Added subscriber: @RedMser
Added subscriber: @Garek
Added subscriber: @Robonnet
Added subscriber: @GeorgiaPacific
Added subscriber: @Kuboa
Added subscriber: @Cigitia
Added subscriber: @lichtwerk
@JacquesLucke : I assume all newly created DESIGNs from your side are confirmed?
Added subscriber: @Galagax
Hello Jacques,
It has been any discussion on this prototype?
Thanks for your time
