Cycles: Motion blur causing some frames to render objects incorrectly #95475
5 Participants
Reference: blender/blender#95475
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.23
Broken: version: 3.0.1, branch: master, commit date: 2022-01-25 17:19, hash:
dc2d180181
Broken: 2.9+ including 3.1 Beta
There is an issue when motion blur is enabled in render settings while using Cycles that results in some objects in scene having incorrect lighting and material properties for one or more frames.
None of the below errors occur with Motion Blur disabled.
If the frame is the first frame to be rendered, it will always render correctly. However if the frame is rendered after another, it will always fail. See steps.
I've seen this issue with numerous files, though the actual frame number that errors is seemingly random. I assumed it was my pipeline until another user I know found the same issue.
It might be related to objects being children of other objects in the scene hierarchy. It only seems to effect animated objects.
I have attached a blend file. Note that Render settings have Motion Blur enabled with shutter length of 1. File is set to render with Optix. Export file type does not matter in this instance.
render_error_reproduction.blend
Render Frame #64 immediately after opening the file, do not make any changes, and view in Render Result. Observe that result should appear like so:
Render any other frame, then re-render #64. You will see one of these three results (full-black, full-bright, and no-object at all):
{F12843849}{F12843851}
If you change the render engine from GPU to CPU and re-render #64 it will succeed. However if you follow the above steps again, while on CPU rendering, the error will once again occur. If you then flip the render engine to GPU Optix again, the frame error will be magically fixed until you repeat the above steps once again.
Closing and re-opening the file allows you to re-render #64 correctly as long as it is the first file to render.
Oddly if you repeat these steps using CUDA instead of OPTIX., the object can disappear entirely and we'll also have other rendering artefacts.
Again none of this occurs with Motion Blur disabled.
While we can work around it by re-rendering specific frames it's a bit of a headache, especially when working with EXR output via command line that we can't easily preview on the fly. Post-process motion blur is also not a great solution for us.
Added subscriber: @Tetrino
Motion blur causing some frames to render objects incorrectlyto Cycles: Motion blur causing some frames to render objects incorrectlyAdded subscriber: @SteffenD
Sounds a lot like a problem with "Persistent Data" on:
Huh, @SteffenD you are entirely correct, I didn't even consider it - is it a known issue?
Added subscriber: @Atair-1
GPU, Nvidia, Optix, Blender 3.0.1
having the same issue - can't share any screens or files, but it involves large scale objects (planets) and small objects (satellites). The planets are 100x smaller to avoid too big issues with the bvh, still after some time problems emerge with persistent data on.
Somehow the bvh gets corrupted? or is not properly built?
All of the above only when motion blur is enabled..
Is there any workaround? because reloading several 20k earth maps per frame is not fun
Added subscriber: @brecht
Appears to be fixed by
94205e1
