Crash when turning on Keep Boundary #95542
7 Participants
Reference: blender/blender#95542
Operating system: Windows-10-10.0.17134-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.11
Broken: version: 3.1.0 Beta, branch: master, commit date: 2022-02-04 20:19, hash:
0b4cf2984f
Here's the file, I can't simplify more.
It's a very specific and weird crash case. not sure really a bug or not.
Open the file, toggle on the first Keep Boundary as shown.
Crash should happen Instantaneously.
CRASH1.blend
Simplified file:
CRASH1_simple.blend
Added subscriber: @Bradley_G
Added subscriber: @deadpin
Confirmed here. In debug builds it will hit the following assert:
Added subscribers: @wannes.malfait, @JacquesLucke
The issue is probably that the Merge by Distance node produced fairly complex non-manifold geometry, that the dual mesh node does not handle correctly.
I simplified the file a bit and attached it to the report above.
@wannes.malfait can you have a look?
Yeah I saw this report and also tried simplifying it a little bit. I think the problem is that there are ngons which have more than 2 edges connected to a single vertex. I did not know that was possible. I tried creating the weirdest types of geometry for my tests, but apparently not weird enough. The current code assumes that each ngon has exactly 1 or 2 edges connected to a vertex, which causes the crash. The assert was there to ensure there was not some weird edge case that was missed for sorting, like this.
I'll try and take a look at it in the coming days. I'm afraid that there will be no "good" solution, either there will be some hole in the mesh, or the resulting dual ngon will have the vertices sorted badly.
In the mean time the best thing to do is add a triangulate node before the dual mesh which "solves" the problem.
Hm, is that really the case? If yes, that sounds like it shouldn't be supported indeed and it may be a bug somewhere else. Doesn't that imply that an ngon has two corners at the same vertex?
I have looked into it a little bit closer, and I have found the problem (or one of the problems). Basically the current code doesn't detect that the central vertex here is "non-manifold":
Then when it tries sorting all the polygon around that vertex it fails, because they can't be sorted. Don't know how easy it is to detect these kinds of vertices without something like the BMesh structure
This issue was referenced by
82fc68ed90
