Random value in geometry nodes produce strange result if it plugged to Instance on point through an attribute #95549
2 Participants
Reference: blender/blender#95549
Operating system: Windows-10-10.0.18363-SP0 64 Bits
Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 432.00
Broken: version: 3.2.0 Alpha, branch: master, commit date: 2022-02-06 00:25, hash:
48fbf0baea
Worked: -
Random value in geometry nodes produce strange result if it plugged to Instance on point through an attribute from another modifier (first modifier). It looks like problem with scale of random value.
Note: Integer Parameter on Random Value also not working (produce strange result)
Random Value as attribute problem.blend
Added subscriber: @Alexander-Bicukow
Added subscriber: @wannes.malfait
This is not a bug. Let me explain why:
TLDR: When you output something from a modifier it is evaluated: stored on the current geometry of the mesh.
@wannes.malfait , so there is no way to use fields through modifiers? Will Capture Attribute node solve this problem?
No, the capture attribute node won't change anything. In this case you either have to subdivide the plane a lot (which still won't give great results) or just use one node tree.
