Retopology in Blender #95584
16 Participants
Reference: blender/blender#95584
This design task is the proposal of implementing settings, operators, and tools that are useful for retopology work.
The biggest driving reason behind this proposal is that retopology work in Blender involves either an ad-hoc set up or add-ons (whether purchased or free). This is due to the very specific nature of retopology work. In particular, retopo work involves the creation of new source geometry (similar to modeling) and pushing around source geometry to straighten edge loops or relax stretched or skewed faces (similar to smooth sculpting brush). However, through all of the manipulating operations, the source geometry needs to remain on the surface of target mesh(es). This means that the tools need to follow up their edit with a snap operation. Due to this closeness, though, the source geometry could be hidden by the target mesh, so care must be taken to ensure the target geometry is appropriately visible over the target(s).
This proposal aims to bring the following ideas into Blender:
The Retopology Mode design document goes into some details about retopology work along with arguments behind some of the design decisions I made.
Work Done
This section describes the work that has been done so far. Some of my work has already been committed, some is still under review, and some of my work has been abandoned for more generalized approaches.
[D14035: Retopology Mode and Overlay ](https://developer.blender.org/D14035)
This patch has been abandoned, as Campbell thought a more general approach would be preferred. Note: left here to show extent of this work.
[D14591: Transform Snap: added nearest face snap mode, added snapping options, lightly refactored snapping code ](https://developer.blender.org/D14591)
This patch allows transformed source geometry to snap to the surface of target meshes, which is critical for retopology work. A few notes:
Face
(nowFace Raycast
) snapping method, as the previous method snapped to the first visible surface under the mouse (raycast through mouse position from view). The new method allows the vertex to snap to the nearest surface, even if it is not visible.[D15154: Expose option to support fallback tools keymap in GizmoGroup type ](https://developer.blender.org/D15154)
This patch allows a
WorkSpaceTool
to use the fallback tools (ex: Select Box) when the mouse is not hovering the activeGizmoGroup
. With this, a new tool can act similar to the built-in tools like Move.[D15398: Expose snap options in transform operators ](https://developer.blender.org/D15398)
This patch allows a tool to set specific snapping options without having to alter the global ToolSettings. With this, each tool can use the snapping options that are appropriate for the given tool. For example:
[D15406: Add Retopology Mode as Snapping Option ](https://developer.blender.org/D15406)
Retopology work involves the creation of new geometry (similar to modeling) but with snapping enabled by default. However, the potential snapping targets will depend on the snapping method under consideration. Specifically, source geometry should snap to the
Without this patch, there are only two options for achieve similar goals (listed below), but neither are ideal.
Ongoing Work
This section describes the work that is still ongoing. Some of this work is dependent on a few patches still waiting to be committed into Blender.
Tool: GeoPen
I have a working prototype of a geometry pen. This tool is similar to Poly Build, but there are differences. Note: some of the differences are simply limitations in Poly Build and could be fixed.
** Nearest geometry is determined in screen space, and unfortunately does not account for occlusion.
Poly Build ignores loose edges and internal edges (edges between two faces). Poly Build cannot create new disconnected patch of geometry.
** Nearest always has a result, so cannot use fallback Box Select with
LeftMouse
drag. Can useB
+LeftMouse
or switch tools...Ctrl
while transforming).** GeoPen does work around some limitations in bpy (see [Experiments: Retopo Translate ]] and [ https:*wiki.blender.org/wiki/User:Jon_Denning/Reports/2022/Experiments#geopen_hiccups | Experiments: geopen hiccups for more details), but this type of tool should be able to be implemented on either side of the API.
Out of all the differences, the first two are key differences in operating paradigm... how the tools operates. While a few of Blender's tools operate in a modal mode (e.g., Knife, Make Line), most of Blender's tools allow the user to change selection and operate on that selection via a Gizmo (e.g., Extrude Region, Inset Faces, Bevel, Smooth, Edge Slide, etc.). Valid arguments can be made for either approach.
The main argument behind using selection rather than nearest is: the tool does not make decisions on the behalf of the user. In other words, it is always clear what GeoPen will do next as the context is clear, while Poly Build depends on where the mouse is relative to the projected geometry (which comes with its own set of known quirks like rounding errors).
Blender Manual
I have started updating the Snapping Options of Blender Manual to reflect the work listed above.
A possible option is to add a subsection that discusses retopology-specific work, but this would better fit under a Retopology section, especially when more tools are ready.
Render
As the retopology mode patch was abandoned, this area of retopology might not get touched.
Although, I do have some ideas on a button / add-on that can adjust settings to be more ideal for retopo work.
Added subscriber: @gfxcoder
Added subscriber: @Dangry
Added subscriber: @ErickNyanduKabongo
Added subscriber: @Andruxa696
Added subscriber: @Yuro
Added subscriber: @TheRedWaxPolice
Added subscriber: @AlexeyAdamitsky
Added subscriber: @Aleks41-3
Added subscriber: @DARRINALDER
Added subscriber: @VupliDerts-2
Added subscriber: @Emi_Martinez
Added subscriber: @Doowah
Added subscriber: @zNight
Added subscriber: @JonathanLampel-4
Retopology Mode in Blenderto Retopology in BlenderAdded subscriber: @VDC
