OpenGL Invalid Enum #95592
7 Participants
Reference: blender/blender#95592
Operating system: macOS-12.1-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Apple 4.1 Metal - 76.3
Broken: version: 3.1.0 Beta, branch: master, commit date: 2022-02-06 19:53, hash:
1d59a7aa77
Worked: 2.93.6, 3.0.1, 3.2.0 Alpha
Something in the Blender startup is causing an
Invalid Enum
OpenGL to occur.Exact steps for others to reproduce the error
Run the following in the Python Console after starting Blender with default scene and factory loaded settings.
Added subscriber: @gfxcoder
Added subscriber: @dodo-2
Verified, i can reproduce the error.
Added subscriber: @JacobMerrill-1
apple does not have openGL
I think the gpu module needs to be used here (to use metal?)
Added subscriber: @LazyDodo
Yeah.... no... apple doeshave opengl and we use it, there is a metal backend for cycles, but everything else is good'ol openGL
@gfxcoder can you try starting blender with the
--factory-startup --debug-gpu --log gpu.* --log-level -1
flags and attaching the log?@LazyDodo, see attached.
log
Added subscribers: @fclem, @michael64
Thank you @gfxcoder for reporting this issue. There are a few things going here.
Let's start with the symptom of the 1280 error code.
Blender uses the the function
check_gl_error
ingl_debug.cc
to check and report OpenGL errors.Since
8be20fcc61
check_gl_error
does not even callglGetError()
if blender is not run with--debug-gpu
.So if you'd run run blender with
--debug-gpu
you should get error code 0 again because it was read bycheck_gl_error
.But there actually was an error 1280 that was not reported by
check_gl_error
.I think this missing error report is due to
0d1f65e516
where the logic if an error should be reported was always incorrectly inverted.The standard logging level for
gpu.debug
isCLG_SEVERITY_WARN
(=1) and the error that wasn't reported hadCLG_SEVERITY_ERROR
(=2) so more severe.In the
debug_callback
which is used bycheck_gl_error
we have the line:```
if (((LOG.type->flag & CLG_FLAG_USE) && (LOG.type->level >= clog_severity))) {
I actually ran into the same issue and just forgot to push the fix.
I guess the error comes from the
glGetIntegerv
we do to get the capabilities and limits of the context. But it is not obvious which one is not available on all systems. I'll see if I can reproduce on my intel Mac.probably unrelated, but i'll post here as an update: when I tried building with DEBUG and running blender in lldb, it stop with an invalid enum error when creating shaders at startup (
workbench_taa
,workbench_composite_matcap
, others?). I traced this issue to the default value for the final parameter ofsampler
function ingpu_shader_create_info.hh
. when I changed the default value from-1
(which is not a value ineGPUSamplerState
) toGPU_SAMPLER_DEFAULT
(see below), lldb no longer stops when creating shaders. however, the Invalid Enum error is still getting set, so this solution does not solve the original problem.This issue was referenced by
883326040e
