GPencil obdata used by more than one object makes depgraph eval extremely slow (affects e.g. liboverrides) #95735
Reference: blender/blender#95735
Operating system: Linux-5.15.5-76051505-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.86
Tested Blender Versions
Broken: version: 3.0.1, branch: master, commit date: 2022-01-25 17:19, hash:
dc2d180181
Broken: version: 3.1.0 Beta, branch: master, commit date: 2022-02-11 22:52, hash:
27d3140b13
Broken: version: 3.2.0 Alpha, branch: master, commit date: 2022-02-11 22:58, hash:
35c261dfcf
Broken: version: 3.2.0 Alpha, branch: greasepencil-object, commit date: 2022-02-02 08:51, hash:
c876bccb57
When using library override with a collection that contains a lattice and a grease pencil object there is a considerable frame rate slowdown.
Library Override Playback
local example.mp4
Expected Result
linked example.mp4
Long description of error
When rigging any grease pencil to a lattice and deforming the lattice in some way yields very good playback speeds. If a collection containing these elements (A grease pencil deformed by a lattice) the collection can be linked to no extra frame rate cost. But when using a library override there is a considerable change in frame rate.
Exact steps for others to reproduce the error from startup file
Exact steps for others to reproduce the error from example .blend
Example Blends: GP Library Override Lattice Issue.zip
Added subscriber: @TinyNick
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Thanks for the report. Can notice reasonable drop in fps with your provided file.
Reports on performance are usually not considered as bug reports (unless they are regression).
Thank you, just some additional context: lattices are often used when rigging grease pencil characters, smaller grease pencil objects dont seem to produce this error (needs testing). I only discovered this because the addition of a new more detailed character unexpectedly tanked my performance.
And this only happens with linking, one can copy and paste the character without a loss in framerate. Meaning this effectively breaks rigged gp characters from being linked across scenes.
Added subscriber: @mont29
I would let #dependency_graph team check on this first...
From a quick investigation, liboverrides are basically ten times slower to evaluate than either fully linked data, or fully local data:
BKE_object_handle_data_update
onOBLattice
BKE_object_eval_uber_data
onOBGP_Pirate.002
Further investigation: issue comes from the fact that the greasepencil obdata (
Pirata.003
) is used by two objects in liboverride case (it has two ID users, the linked object and its local override). Issue being, when evaluated GP ID has more than one user, it is fully duplicated, otherwise it is evaluated 'in place' (BKE_gpencil_prepare_eval_data
)?Copying a GP data takes a lot of time.
I think this is a depsgraph/GPencil issue really.
@TinyNick temporary workaround is to also make the GP obdata itself a liboverride (from the Outliner e.g.).
Library Overides: Low Framerate when using Grease Pencil + Lattice Modifierto GPencil obdata used by more than one object makes depgraph eval extremely slow (affects e.g. liboverrides)@mont29 Thank you, that does appear to work as a temporary workaround. I appreciate the tip it seems to have worked! The playback speed is reasonable using the workaround.
Added subscriber: @antoniov
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
Solved with https://developer.blender.org/D14238
