Hair display error in blender 3.0.1 #95753
Reference: blender/blender#95753
Hello, when I add new hair in the Particle Edit mode. Then the hair does not come from the mesh itself, but as if it weighs above it. What's the problem, maybe I'm doing something wrong?
{F12865495}System Information
Graphics card: AMD Radeon R7 200 Series ATI Technologies Inc. 4.5.148202 Core Profile Context 21.3.1 27.20.15003.1004
Broken: version: 3.0.1, branch: master, commit date: 2022-01-25 17:19, hash:
dc2d180181
Added subscriber: @Evgen-4
Thanks for the report. Please provide .blend file to test the case.
Added subscriber: @Diogo_Valadares
Did you activate B-spline on the hair? this usually is what disconnects the hair from the surface visually.
Yes, Particle Edit mode checked this box, and then drew the hair. Should I have done this before the Particle Edit mode or not in the mode itself?
Explain why B-spline is needed then, if when it is activated, the hair particles come off and weigh over the mesh. I watched different videos and there B-spline was made by the number 5-7. Or is this function already useless in version 3?
This is a visual effect of the b-spline, but I'm not sure if this is intended behavior of this option. I noticed this sometime ago but never reported.
just turning b-spline off should "connect" it. if not, please, share the .blend file so it can be checked.
volosy_proekt_blend.blend
Here is my project, I apologize for the naked body of the mesh. See what I'm doing wrong, give advice or intsructions
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Yes, the problem is because of the B-spline. but I'm not sure if this is intended behavior.
I also noticed that if you change the key when using this function, then the hair falls into place. For example, there was a key of 10, and change to 20 with the help of hair selection, then right-click and change the key. Or edit each hair manually when unchecking the root position.
Tell me, what should I do in such cases, not to use the B-slide at all, or how would I change the keys at my discretion when using it?
If we move this out of the triaging queue (by changing status label to
Needs Information from Developers
), this needs to be the responsibility of a module (so aModule
label must be added)
