Library Override - 'Cherry-Picked' Properties #95816
Open
opened 2022-02-16 13:15:17 +01:00 by Bastien Montagne · 14 comments
General Idea
The idea behind this task is to help with collaboration between the different pipeline stages artists. In a nutshell, the artists creating an asset will be able to define which properties should be typically editable by the artists using this asset.
While the primary goal of this task is to handle the library overrides case, this feature should not be limited to them, not even to overrides in general.
The main two ideas are:
  • Defining a set of 'cherry-picked' properties for each data-block, when creating the asset. Then add a 'filtered' mode to the properties editor, that would only show those favorite properties. This filtered mode would be enabled by default for library override data-blocks.
  • Non-cherry-picked properties remain editable, but there will be tools (in the Outliner, and RNA/python API) to quickly detect and revert those if they are edited.
NOTE: This design is the latest evolution of the 'restrictive workflow' idea.
UI/UX, Workflow
A new filtered option will be added to the Properties editor, only enabled by default for linked/overridden IDs, when they do define a set of cherry-picked properties.
A new mode will be added to the Outliner, to help visualizing and bulk-editing 'cherry-picked' properties.
Creation
Defining which properties are cherry-picked (and therefore shown by default when the data is linked and overridden) will happen during asset creation.
Whole data-blocks may also be defined as 'cherry-picked', in which case all of their properties will be shown/editable.
The main place to define them will be the properties editor (from an entry in the contextual menu on the relevant widgets). The same option could also be added to the contextual menu of the 'Data API' view in the Outliner, for completeness.
Visualizing/editing defined favorite properties can happen either from the Properties editor itself, by toggling the filtered mode on, and/or using some visual feedback on their widgets (specific color, hashed-grayed-out...), or from the dedicated mode in the overrides Outliner view.
Usage
By default, users of a linked/overridden data-block which has cherry-picked defined, would only see these in the properties editor.
They can toggle the filter off though, if they want to have access to other properties.
The Outliner Overrides views will show a warning when a non-cherry-picked property has been edited.
Technical Implementation
While they have a lot in common with liboverrides, 'cherry-picked properties' should be implemented in a separate data structure/BKE module, as they also can extend beyond liboverrides scope. The idea of 'liboverride templates' is then not used here.
Proposal is then to have a new optional struct (through pointer) in ID, with a general flag (e.g. to define the ID as fully editable), and a 'allow' list of RNA paths (+ flags potentially) for the 'cherry-picked properties'.
The basic management code would be in a new BKE module (BKE_lib_cherrypicked_properties or so). Ideally some generic handling could be factored out of this module, the liboverride one, and potentially the future dynamic override one, in the future.
An RNA-based API will be added for scripts control.
Changes to the outliner and properties editor code needs to be defined.
Changes to the existing liboverride code is expected to be minimal. One side task may be to clean up the 'half-dead' code of the initial 'template' implementation, could simplify slightly the liboverride code.
Tasks
  • Decide on actual name: "Favorite Properties"? "Exposed Properties"? "Principal Properties"? "Cherry-Picked" properties
  • Create an Icon for them (with ON/partially ON/OFF variants). For now, the 'eye' one could be used.
    Could be e.g. some mix of 'heart' and 'system' icons? {F12890805}
  • Create the low-level BKE code and DNA data structures.
  • Create the RNA API.
  • Add the Properties editor filtered view.
    • Add a 'only show' mode (i.e. fully hide the filtered out properties)?
    • Add a specific 'grayed-out' mode (e.g. using a hash-pattern grayed-out)?
  • Add a visual feed-back in library file about which properties are cherry-picked (could be e.g. a new 'column' next to the 'animation' one, or a specific background/border color for the widgets).
  • Add the 'Cherry-Picked' view to the Outliner (or as a new mode for the 'Blender File' view?).
  • Add entries to the contextual menu in Properties and Outliner editors (including high-level management operators).
General Idea **** The idea behind this task is to help with collaboration between the different pipeline stages artists. In a nutshell, the artists creating an asset will be able to define which properties should be typically editable by the artists using this asset. While the primary goal of this task is to handle the library overrides case, this feature should not be limited to them, not even to overrides in general. The main two ideas are: * Defining a set of 'cherry-picked' properties for each data-block, when creating the asset. Then add a 'filtered' mode to the properties editor, that would only show those favorite properties. This filtered mode would be enabled by default for library override data-blocks. * Non-cherry-picked properties remain editable, but there will be tools (in the Outliner, and RNA/python API) to quickly detect and revert those if they are edited. NOTE: This design is the latest evolution of the 'restrictive workflow' idea. ------------------------------- UI/UX, Workflow **** A new filtered option will be added to the Properties editor, only enabled by default for linked/overridden IDs, when they do define a set of cherry-picked properties. ![overrides_favorites_propertyeditor.png](https://archive.blender.org/developer/F12869781/overrides_favorites_propertyeditor.png) A new mode will be added to the Outliner, to help visualizing and bulk-editing 'cherry-picked' properties. ![overrides_favorites_outliner.png](https://archive.blender.org/developer/F12869783/overrides_favorites_outliner.png) Creation ---------- Defining which properties are cherry-picked (and therefore shown by default when the data is linked and overridden) will happen during asset creation. Whole data-blocks may also be defined as 'cherry-picked', in which case all of their properties will be shown/editable. The main place to define them will be the properties editor (from an entry in the contextual menu on the relevant widgets). The same option could also be added to the contextual menu of the 'Data API' view in the Outliner, for completeness. Visualizing/editing defined favorite properties can happen either from the Properties editor itself, by toggling the filtered mode on, and/or using some visual feedback on their widgets (specific color, hashed-grayed-out...), or from the dedicated mode in the overrides Outliner view. Usage ------- By default, users of a linked/overridden data-block which has cherry-picked defined, would only see these in the properties editor. They can toggle the filter off though, if they want to have access to other properties. The Outliner Overrides views will show a warning when a non-cherry-picked property has been edited. Technical Implementation **** While they have a lot in common with liboverrides, 'cherry-picked properties' should be implemented in a separate data structure/BKE module, as they also can extend beyond liboverrides scope. The idea of 'liboverride templates' is then not used here. Proposal is then to have a new optional struct (through pointer) in ID, with a general flag (e.g. to define the ID as fully editable), and a 'allow' list of RNA paths (+ flags potentially) for the 'cherry-picked properties'. The basic management code would be in a new BKE module (`BKE_lib_cherrypicked_properties` or so). *Ideally some generic handling could be factored out of this module, the liboverride one, and potentially the future dynamic override one, in the future.* An RNA-based API will be added for scripts control. Changes to the outliner and properties editor code needs to be defined. Changes to the existing liboverride code is expected to be minimal. One side task may be to clean up the 'half-dead' code of the initial 'template' implementation, could simplify slightly the liboverride code. Tasks **** - [x] Decide on actual name: ~~"Favorite Properties"? "Exposed Properties"? "Principal Properties"?~~ "Cherry-Picked" properties - [ ] Create an Icon for them (with ON/partially ON/OFF variants). For now, the 'eye' one could be used. *Could be e.g. some mix of 'heart' and 'system' icons? {[F12890805](https://archive.blender.org/developer/F12890805/favorite_props_icon_proposal.png)}* - [ ] Create the low-level BKE code and DNA data structures. - [ ] Create the RNA API. - [ ] Add the Properties editor filtered view. - [ ] Add a 'only show' mode (i.e. fully hide the filtered out properties)? - [ ] Add a specific 'grayed-out' mode (e.g. using a hash-pattern grayed-out)? - [ ] Add a visual feed-back in library file about which properties are cherry-picked (could be e.g. a new 'column' next to the 'animation' one, or a specific background/border color for the widgets). - [ ] Add the 'Cherry-Picked' view to the Outliner (or as a new mode for the 'Blender File' view?). - [ ] Add entries to the contextual menu in Properties and Outliner editors (including high-level management operators).
Author
Owner
Author
Owner
Added subscriber: @mont29
#86812 was marked as duplicate of this issue
Author
Owner
Added subscribers: @Jeroen-Bakker, @RedMser, @lichtwerk
Bastien Montagne changed title from Library Override - 'Favorite' Properties to Library Override - 'Cherry-Picked' Properties 2022-05-17 16:34:05 +02:00
Added subscriber: @Emi_Martinez
Added subscriber: @AlexeyAdamitsky
I'd like to contribute an icon for the task.
100%
200%
There are two versions: outline and filled. They have small differences but I am open to adjust any of them for the final design.
It's my first contribution so I'm might need some guidance how to proceed further and who to contact regarding this if it's something worth exploring further.
I'd like to contribute an icon for the task. ![Figma_MCIO4rvXbf.png](https://archive.blender.org/developer/F13126197/Figma_MCIO4rvXbf.png) 100% ![Figma_06q6uQJbKs.png](https://archive.blender.org/developer/F13126200/Figma_06q6uQJbKs.png) 200% There are two versions: outline and filled. They have small differences but I am open to adjust any of them for the final design. It's my first contribution so I'm might need some guidance how to proceed further and who to contact regarding this if it's something worth exploring further.
Added subscriber: @dfelinto
@AlexeyAdamitsky thanks. We changed the name and in a way the purpose of this a bit. Now it is closer to "cherry-pick". In that sense the concept of a heart (and/or cogs) doesn't apply anymore.
On an icon level I also find that the cogs don't work when reduced (when the icon is seeing at the UI. The teeth of the cog end up just adding a fuzzy noise.
@AlexeyAdamitsky thanks. We changed the name and in a way the purpose of this a bit. Now it is closer to "cherry-pick". In that sense the concept of a heart (and/or cogs) doesn't apply anymore. On an icon level I also find that the cogs don't work when reduced (when the icon is seeing at the UI. The teeth of the cog end up just adding a fuzzy noise.
@dfelinto Those are valid points. Let's explore another concept. I re-read the design brief and decided to go a little bit more straight forward with the icons borrowing from existing solutions.
Left to right: on, off, partially on status.
100%
200%
Let me know if this is a good direction or not. Meanwhile, I'll explore about another original icon design.
@dfelinto Those are valid points. Let's explore another concept. I re-read the design brief and decided to go a little bit more straight forward with the icons borrowing from existing solutions. Left to right: on, off, partially on status. ![Figma_YbpOSV7viq.png](https://archive.blender.org/developer/F13135155/Figma_YbpOSV7viq.png) 100% ![Figma_Etb0Z7PG38.png](https://archive.blender.org/developer/F13135158/Figma_Etb0Z7PG38.png) 200% Let me know if this is a good direction or not. Meanwhile, I'll explore about another original icon design.
Added subscriber: @Logan-Gardner
I decided to clean up one of the ideas. Rearranging some elements to simplify the icon even further to remove some visual noise. I think it works pretty well for the task.
100%
200%
400%
I'll keep exploring other ideas in my spare time.
I decided to clean up one of the ideas. Rearranging some elements to simplify the icon even further to remove some visual noise. I think it works pretty well for the task. 100% ![Figma_JwXdVMkyKz.png](https://archive.blender.org/developer/F13265536/Figma_JwXdVMkyKz.png) 200% ![Figma_ZhUZNmyzeX.png](https://archive.blender.org/developer/F13265538/Figma_ZhUZNmyzeX.png) 400% ![Figma_oWftJ00LgR.png](https://archive.blender.org/developer/F13265540/Figma_oWftJ00LgR.png) I'll keep exploring other ideas in my spare time.
Added subscriber: @pauanyu_blender
Added subscriber: @satishgoda1
Philipp Oeser removed the
label 2023-02-09 14:42:51 +01:00
8 Participants
Reference: blender/blender#95816
