Regression: Curve wire line not displayed in edit mode when it has evaluated mesh/point/volume #96138
9 Participants
Reference: blender/blender#96138
Broken: 3.0, 3.1, 3.2
Caused by
b9febb54a4
The original line for edit mode curves is not displayed in edit mode .
This change only applies when the curve is changed during evaluation, for example, when it is replaced by an evaluated "tube" mesh, or points, or a volume, etc.
#99926 was marked as duplicate of this issue
A couple things to say here:
Curve Line not always displayed in edit modeto Curve wire line not always displayed in edit modeChanged status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @funksy
Added subscribers: @DavidKozma, @viadvena, @item412, @lichtwerk
Line misses in objectmode, too.
For me, it just makes it harder to line things up exactly (if I dont see the line the generated geometry is based upon).
Personally, I would still think this is High priority.
Curve wire line not always displayed in edit modeto Regression: Curve wire line not displayed when geometry is generated for it (e.g. bevel, extrude, ...)Added subscriber: @aicedor
Hello. Please leave the curve line visible so it can be selected (or give it a new show/hide function in the Overlays menu). It would also be nice to be able to choose the color of the curve and its thickness regardless of the wireframe settings for the mesh (this is more like a feature request, I'll prepare a proposal). Often curves in object mode in the viewport are lost in the background of the mesh.
The line isn't missing in object mode. It's not meant to be displayed in that case, for a few reasons:
I agree edit mode should be fixed, to display the wire edges of the original curve, just like in mesh edit mode.
Regression: Curve wire line not displayed when geometry is generated for it (e.g. bevel, extrude, ...)to Regression: Curve wire line not displayed in edit mode when it has evaluated mesh/point/volumeIt is missing in objectmode when
This was working in 2.93.
I dont see a reason for changing this, this has never been discussed anywhere, has it?
Of course, #modeling module is free to decide and if this cannot be done anymore for performance reasons than so be it, but just because the curve now has a mesh associated with it is not an entirely convincing argument for not drawing the curve anymore in my opinion.
Regression: Curve wire line not displayed in edit mode when it has evaluated mesh/point/volumeto Regression: Curve wire line not displayed in edit mode (or wireframe display mode) when it has evaluated mesh/point/volumeThat behavior change should have been mentioned more explicitly in the original commit message, but it is a fundamental aspect of the current design, which is basically: creating a mesh from the curve replaces the curve. The resulting mesh does not have any specific knowledge of the curve it was generated from.
This is a natural consequence of generalizing the result types from object evaluation. Here's an example. Imagine you use the curve to mesh node to generate a tube mesh for a curve, then significantly deform it, and apply more procedural operations. Then you combine that with another procedurally curve for the final result of object evaluation. How does Blender know the initial curve used to generate the tube mesh, in order to display it in wireframe mode? It doesn't, that's just not possible in the general case.
Part of the change in that commit was eliminating the "quasi-mesh/quasi-curve" state that still persisted in the curve modifier stack through types like
DispList
. Showing the wire edges in object mode might make sense in that case, but now that this half-way state is gone, that's no longer the case.Again, edit mode is different, because the original data is just a curve in these cases, so the wire lines can be drawn.
In the future, could we please have these conversations in comments before editing the task?
Removed subscriber: @item412
From a user's standpoint, I wouldn't miss seeing the curve line in Wireframe mode, just because that mode is very cluttered with actual edges anyway.
BUT I think having at least an overlay which shows all curves in object mode (even if they have meshes generated) is a must.
In 2.93 if - I really wanted - I could achieve this with turning ON wireframes but setting their Opacity to 0. That still left the curves show up.
the same option leaves me nothing in newer versions of course, so a separate curve visibility option would be very nice!
Anyway thank you for properly dealing with the bug.
You can have that visualization if you join the original curve with the evaluated mesh with geometry nodes. I realize that's not the same thing, I just want to point out that the flexibility and generality of the new design brings options like that. When we have a default "to mesh" node group in the asset browser, there could be a boolean option like "keep curve" for this use case.
The new
Curves
object type will have an implicit surface rendered in Cycles and hopefully EEVEE, eventually. In those cases such an option might make sense.Split objectmode into own report, see #96167 (Regression: Curve wire line not displayed in wireframe display mode when it has evaluated mesh/point/volume)
Regression: Curve wire line not displayed in edit mode (or wireframe display mode) when it has evaluated mesh/point/volumeto Regression: Curve wire line not displayed in edit mode when it has evaluated mesh/point/volumeAdded subscriber: @ThomasDinges
@ThomasDinges , @HooglyBoogly : since this is a regression, just asking if this is still relevant for 3.1?
No, I don't think so, since the right way to fix it isn't clear to me.
I could only test it now, and I finally understand how you've split the bug into 2 tasks.
Yes, the visible object selection in edit mode was bothersome, and thanks a ton for fixing it!
But this one above is the one which makes it hard to work with curves now. We need to see them in edit mode no matter what!
Added subscribers: @MikhailRachinskiy, @PratikPB2123
I think it should be out of the question, that edit mode should allow user to see the curve they're editing, it does not make sense to see control points, but not a curve.
By curve I mean original datablock.
Yes, 100% (and now I'm waiting for this regression fix for about 8 months)
I mean absolutely no offense but that's only a programmer's logic that if you turn something into another datablock non-destructively then that's done. It's different now, and you don't need to see the original data's editing elements when you'd like to change something.
OFF topic: the Bevel modifier kills Edit mode visibility of other constructive modifiers. That's a similar usability PITA as not seeing the curve, but hinders work way less than this.
Added subscriber: @dupoxy
To clarify, what I meant above is that we shouldn't try to somehow display a wire line in object mode when the object evaluates to a mesh. It makes sense to display in edit mode, or at least it should be an option.
That said, the existing curve object type is being replaced in the next couple releases, and realistically I don't think someone will have the time to fix this before that, so I'll make this a "known issue".
