shrinking to zero doesn't actually scales the radius to zero #96238
Reference: blender/blender#96238
Graphics card: AMD Radeon RX 5700 XT ATI Technologies Inc. 4.5.14802 Core Profile Context 22.2.1 30.0.14023.7007
Broken: version: 3.2.0 Alpha, branch: master, commit date: 2022-03-04 16:11, hash:
295d5c6ef5
if you use alt+s and then type 0, the radius of the the curve goes to 0.001 instead of 0
2022-03-08 10-54-21.mp4
you can resize it to any number without any problem, but specifically at 0, instead of setting the radius to 0 it sets to 0.001
Extra note: This may be better reported in another thread but while reporting this bug I noticed that the status bar where you type the numbers wrongly says that the operation is shrink/flatten, but there is no such thing for curves, it probably should be something as scale point. I tried to find it in documentation and I only found that alt+s should be using "radius" but in this case the documentation would be wrong because we are not defining the radius of the point directly, we are scaling it. https://docs.blender.org/manual/en/latest/modeling/curves/editing/curve.html#radius
Summing up this extra note:
alt+s mode naming in curve edit in blender is probably wrong
the operation may also be wrong, but I'm not sure if its wrong in blender or if its wrong in the documentation
Added subscriber: @Diogo_Valadares
Added subscribers: @mano-wii, @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Hm, this was like that since forever.
@mano-wii : since there is no real limit in RNA, would you have an idea why transform code limits it to
0.001f
?Added subscriber: @broken
This has been the case since when the operator was implemented in
d3028ec70d
.Maybe only @broken knows the answer.
My guess is that this was done to prevent the operation from getting stuck after successive Shrink Fatten calls if one of them results in a radius of 0.0.
But that doesn't prevent this radius from being set to 0.0 from the UI.
So it doesn't seem like a valid reason to limit the value.
Here a possible solution:
I guess Matt isn't active anymore, so I don't know if we will get an answer anytime soon...
I usually like to set the radius of hair tips to 0 and the only problem I have is if I want to increase the size later, tho it can be done by manually setting the size in the N-Panel.
Having this soft limit usually gives me problems whenever I need to merge the tips of the curves.
This issue was referenced by
2d1fe736fa
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
