backward compatibility issue: old files break all addons that use render layer socket identifiers due to naming convention change. #96239
Reference: blender/blender#96239
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 2.79
Back in the days (some time between 2.73 and 2.79), it appears that some sockets of the
Render Layer
node had theidentifier
different from thename
.This can be seen for example with the
DiffDir
socket which in old files (2.73) had the identifier named'Diffuse Direct'
and in new files it is layered'DiffDir'
.This makes it impossible to use socket identifiers reliably. This is worsened by the fact that socket identifiers are read only, so can't be upgraded by the addons.
It's not feasable for addons to use the socket.name because this will break functionality on non render layer nodes....and in my case is a substantial amount of work to update many thousands lines of code.
Could these be automatically renamed to match the current standard during the versioning checks on file load?
Scripting
Workspace
The result will be inconsistent if we compare with new files:
Added subscriber: @3di
Added subscriber: @mano-wii
Thanks for the report, but please try to make the triaging team's work a little easier by giving a little more context and steps to reproduce the error.
Since you mentioned
DiffDir
I assume you are referring to theRender Layers
node with theCycles
engine in context, am I right?When was this node's identifier called
Diffuse Direct
?From what I can see it is called
DiffDir
since version 2.79:So how old is this "backward compatibility issue"?
*(A guideline for making a good bug report can be found at https:*wiki.blender.org/wiki/Process/Bug_Reports )//
Hi, I'm not sure of the blender version in which this change occurred, but the issue is there in the benchmark classroom scene. Yes, as mentioned in the report, I'm referring to the render layers node, EEVEE wasn't about at the time and the Blender Render engine is no longer in Blender, so yes I'm referring to Cycles 👍 Sorry I thought this was obvious, particularly as I mentioned this is apparent in the classroom benchmark scene which uses cycles.
Also, in your print above you're printing out the socket names, this is not related to what was said in the report.
Please use:
Just to confirm, if you open the classroom benchmark scene, and run the code I gave above, you should be able to see the issue 👍
If you then run the same code in a new scene, you'll notice the socket identifiers now match the socket names (the new naming convention for socket identifiers).
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscriber: @brecht
This seems to be intentional seenc74c72101e
.@brecht, since you are the author of the commit, how to proceed here, confirm this backward compatibility break as a bug or is it more of a Known Issue?EDIT: the problem is older
@mano-wii thanks. That commit seems only related to custom passes. This report is entirely about the built in passes. So custom passes should remain untouched by suggested versioning renaming.
Removed subscriber: @brecht
Not sure if I understand the report correctly, but I don't think I would consider it a bug. While it's generally nice to avoid changing identifiers to provide a stable Python API, there will be some changes necessary in different versions of Blender, this is expected.
@HooglyBoogly Isn't the purpose of the versioning checks to ensure old files work with new standards? What potential issues do you see?
Yes, changes are usually versioned. That's not always possible though. And since this happened many years ago, I don't think we would address it with new versioning now.
It's a shame because it would have no negative consequences beyond what's expected with versioning changes (backward compatibility), and would immediately get a ton of addons working no doubt. I was talking to someone the other day who's still trapped on an old version of blender because the addon developers haven't updated their addons.
For me I've already coded the workaround now, but it was a massive amount of work, which I'd guess many addon developers would avoid in favour of discontinuing their addon.
This one's particularly nasty because the identifiers are read only, removing the possibility of updating the offending properties to the current standard from within the addon.
Perhaps someone could update the benchmark scenes you provide as a lesser than ideal alternative?
I'm probably not getting my point across very well. Addon developers should modify addons to meet api changes, but if it's a versioning issue such as this that's not addressed in blenders versioning checks, it means they effectively have to build addons that will work with files from every version of blender. It's an unrealistic proposition to trudge through every blend data convention change and then develop multiple functions to cater for them all. In this case one function to rename socket identifiers to the current standard will save a huge amount of effort and unfathomable bugs for countless developers I'd imagine.
