Regression: Crash when accessing animated 'object.data' property in a driver of a Mesh #96289
7 Participants
Reference: blender/blender#96289
Graphics card: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.65
blender_system_info.txt
Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash:
c77597cd0e
Worked: version: 3.1.0 Alpha, branch: master, commit date: 2022-01-23 19:27, hash:
abf30007ab
Apparently, this is caused by
56407432a6
Drivers accessing properties of other Meshes may crash.
This was noticed when performing F12 render or spacebar animation on certain models
As far as I can tell, more than half of the models I have checked do not allow most operations (I suspect my models are biased).
No problem in 3.0. All daily builds are unconfirmed, but 3.1.0 Alpha, branch: master, commit date: 2022-01-23 19:27 was the latest I checked that works.
Crash Log:
qulle-3.1test.crash.txt
data.shape_keys.key_blocks["Key 1"].value
)Simplified file:
drivers_crash-simplied_only_one_shapekey.blend
Original file:
qulle-3.1test.blend
Added subscriber: @poopoo
#97710 was marked as duplicate of this issue
Crash when performing F12 render or spacebar animation on certain modelsto Crash when performing F12 render or spacebar animation on certain models in 3.1Added subscriber: @PratikPB2123
Added subscriber: @mano-wii
I can confirm the crash. It happens inside some driver.
But the .blend file is too complex. It needs to be simplified before we confirm and forward it to the developers.
I was able to simplify the file but I couldn't do a bisect to find the causing commit, because the behavior changes between Debug and RelWithDebInfo and many of the commits had to be skipped due to the error:
LNK1201 error writing to program database 'D:\Dev\BlenderDev\x64-Debug\source\creator\Debug\tf.pdb'; check for insufficient disk space, invalid path, or insufficient privilege blender D:\Dev\BlenderDev\x64-Debug\source\creator\LINK 1
I've spent a long time trying to bisect without success.
drivers_crash.blend
Crash when performing F12 render or spacebar animation on certain models in 3.1to Crash when accessing a shapekey property of a Mesh in a driver of another MeshThis comment was removed by @poopoo
Thanks for identifying the cause.
I have created a simplified version with only one shape key from your file.
"accessing a shapekey property of a Mesh in a driver of another Mesh" does not necessarily cause a crash.
Manually moving the A shape key does not cause a crash
Crashes when keyframes are set on A and animation is performed.
Thanks for the info and for simplifying the file even further. It sure helps!
I will update the description.
Crash when accessing a shapekey property of a Mesh in a driver of another Meshto Crash when accessing an animated shapekey property of a Mesh in a driver of another MeshThis comment was removed by @poopoo
Sorry to keep writing additional information.
I have found one more crashing condition to report.
Safe Driver setting in 3.1
SingleProperty
Prop = Key
Path=key_blocks["Key 1"].value
Crash Driver setting in 3.1 ( safe in 3.0)
SingleProperty
Prop = object
Path=data.shape_keys.key_blocks["Key 1"].value
driver=object-crash.blend
driver=key-safe.blend
Crash when accessing an animated shapekey property of a Mesh in a driver of another Meshto Crash when accessing animated 'object.data' property in a driver of a MeshCrash when accessing animated 'object.data' property in a driver of a Meshto Regression: Crash when accessing animated 'object.data' property in a driver of a MeshAdded subscribers: @kevindietrich, @lichtwerk
56407432a6
CC @kevindietrich : mind checking?
Added subscribers: @Sergey, @dr.sybren
Better to share than to keep secret :)
This seems to be the same issue as #97710 (Regression: Crash When Appending Items and Editing Expressions).
Having
as driver variable expression has never (AFAIK, anyway) been safe since Blender 2.80 (which introduced the new-at-the-time depsgraph). #97710 has an example file that can crash 2.80 as well, even though it looked like56407432a6
caused the issue. I think that commit simply changed the threading behaviour and caused the prior problem to become more prominent.You can have the driver variable target the key directly, but the problem is that the shapekey names are not shown anywhere in the UI. They're always called
Key.nnn
, making it hard to work with. What you can do is target the Mesh instead, and useshape_keys.key_blocks["Key 1"].value
(i.e. just remove thedata.
from the old path).@Sergey do you think this analysis is correct?
Added subscriber: @ChrisJones
@dr.sybren, I vaguely remember the issue. Also remember some work was done on it. The crash is never good, and it is not an implicit design limitation of drivers referring to other IDs. In contrast, it should be totally possible to reference any ID from the expression. Think either we are missing a relation, or we need to do something special to keep shapekeys on the result so that values can be used from them (the latter one is AFAIR the patch you've worked on a while ago. Think it was committed but some of the optimization work later one might have undone it).
Thanks for the info.
I will comment on one point.
In Japanese amateur 3D user, a tool called MMD (Miku Miku Dance) is very popular and has a extensive collection of animation style model and motion assets.
There is an add-on called mmd_tools that uses this asset for MMD in blender, but since this add-on uses this crashing shape key setting internally, mmd_tools users are unable to use blender 3.1 or later.
I understand that blender has various priorities for adding features and bug fixes, and usually, if there is a simple workaround, bug fixes are not a priority, but I wanted to tell you above that in some communities this bug has a significant impact.
Another idea is to address the issue on the mmd_tools side, but the maintainer does not intend to fix this issue with the bug/spec on the blender side yet to be finalized.
My earlier analysis wasn't quite correct, as it turns out adding an
RNAPathKey
relation already does the RNA path parsing. The crash seems to be caused by the changed semantics ofobject.data
: before56407432a6
it was safe to use when the pointer is valid, so even when the data it points to was not yet evaluated properly. This has now changed, but the depsgraph relations haven't been updated to account for this.This issue was referenced by
a2dacefb46
