NLA Visual Bake of Actions (with Rigify character) Gives broken results. #96459
Reference: blender/blender#96459
Operating system: Windows 10 Home 64bit
Graphics card: GeForce RTX 2080
Broken: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash:
c77597cd0e
, type: release, build date: 2022-03-09, 00:44:13Worked: 3.0 and later - All that can open this file correctly.
(Files provided for testing)
you'll find a stack of NLA Action strips resulting in desired animation.
Baking those actions into a single Action using visual keying results in Broken looking animation (baked action is set to Replace).
Additionally even though the resulting strip is set to replace and placed as the top layer. Turning Layers on/off below it affects the resulting pose on the character.
One would expect once the top layer is set to Replace, anything happening in the lower layers should have no apparent effect and could safely be removed from the NLA.
Attached Viewport Renders of Pre and Post Bakes for reference.
Attached Character rig used as a Library override (save and relocate the library override from the outliner in the Animation file)
Attached The Animation File in which I am attempting to Bake.
MomoDebug_A_rig.blend
BadBakeNLAActions.blend
Turn on all other tracks below
Result:
I couldn't remove the layers below without breaking the animation.
Added subscriber: @AgeofGar
Added subscriber: @OmarEmaraDev
I can't seem to replicate the issue, but I feel there is a step missing. Can you give more detailed instruction on how to replicate the issue? Here is what I did:
This comment was removed by @AgeofGar
Ok @OmarEmaraDev I found the problem !
The Rig Main Properties do not get baked for me. I'll send you a screen shot.
Here's how rig properties are keyed in the strip at the bottom.
Here's how they look in the Baked strip: not keyed
Because of that they inherit the values of whichever Strip was enabled then disabled last:
Here's what the same controls look like after enabling/disabling the second to last track.
Because of this you could accidentally make the result of your bake look right, or broken when you don't realize this his happening.
Added subscriber: @iss
@AgeofGar Following comments should be reported separately. Also this file is very complex I think developers would be very unhappy about this. From your last comment it sounds like this should be relatively easy to reproduce with much simpler file, but I don't have much experience with NLA, so I am not sure about that. In any case if you can simplify this case it would be much appreciated.
Additional bugginess:
If you turn turn the two bottom layers on/off and scrub the timeline it will affect the result even though the top layer is on and set to Replace. (see the broken videos)
Correct_PreBake.mp4
Broken_LegsPostBake.mp4
Broken_HeadTwist.mp4
Added subscriber: @BClark
"The Rig Main Properties do not get baked for me. I'll send you a screen shot.
Here's how rig properties are keyed in the strip at the bottom."
Yes this is a known issue and long standing problem
https://vimeo.com/503261365
We have a patch that is in the works, one of many to start fixing these issues but the main issue isn't with the NLA or actions, it is with the BAKE
BAKE ACTION- only looks at object or pose and doesn't look at any properties, it is a very limited bake.
@BClark @iss
Since this is known I'm guessing you no longer need a simplified sample file ?
Let me know if that is the case.
Also found the link to the bake issue, but it says it's closed and archived. Is there an active task elsewhere ? I would love to follow this issue until it gets resolved.
Thanks
yeah no sample file needed... and I answered over there on the thread, it is closed because it is a feature request for a tool not a "bug" .
Can you provide link to report here? I guess that would be #65773?
If you agree with that issue is because of animated custom properties influencing position, then I should merge this report. If you think the issue is different, then we will need simplified file. Looking at provided file I am not quite sure what to look for, thare is quite a bit of animation and I don't see custom props there.
As far as I know and understand both from this post and my own experience with the same problem, it is due to the properties being animated but not being included in the new action during the bake.
If you look in the file at the Thigh_parent.r you can see this gear object holds the IK/FK switch properties and since those are animated, when it bakes the animation to the pose bones, the result does not include the switches so the result isn't correct unless you also have the original animation of those properties.
I go through this also in the video I posted https://vimeo.com/503261365
