OpenColorIO-Config-ACES 0.2.0 breaks in sRGB view transform #96590
8 Participants
Reference: blender/blender#96590
Operating system: macOS-12.3-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5700 XT OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.8.13
Broken: version: 3.2.0 Alpha, branch: master, commit date: 2022-03-12 10:29, hash:
f6b7396610
I tested the newest OCIO v2 config from Github (https://github.com/AcademySoftwareFoundation/OpenColorIO-Config-ACES/releases/tag/v0.2.0)
in Blender 3.2 Alpha. It was first time I tried that.
I had to change the OCIO 2.1 version to 2.0 to make it actually work in Blender. I was assured that this shouldn't be a problem.
I rendered a test scene and saw some strange shading errors with the default sRGB view transform.
Selecting a different view transform like Rec.709 fixes the issue.
I posted about the issue on my blog https://www.toodee.de/?page_id=5517 and on ACESCentral.com
https://community.acescentral.com/t/opencolorio-2-configs-for-aces/4354
The rendered EXR file is fine of course. The problem only occurs in the render view or when I try to export the rendered image.
JPG works fine, PNG breaks in a different way and creates a strangely bright image.
Blender_32alpha_OCIOv2_sRGB_bug.blend
I also tested the same .blend file on a new M1Max MBP. There I cannot replicate the error.
Added subscriber: @DanielBrylka
Added subscriber: @EAW
Added subscriber: @Hartmut
Linux also does not have the issue - must be a win-thing then.
Tested on Ubuntu 20.10.
Added subscriber: @OmarEmaraDev
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
I can't replicate the issue, but I consistently get the error:
The sRGB display uses shared views that use
<USE_DISPLAY_NAME>
as theirdisplay_colorspace
value. But it doesn't seem like the OpenColorIO can recognize that and reads it literally, which might be related to the issue you are describing.So I will wait for more information from developers.
Added subscriber: @brecht
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
Supporting
<USE_DISPLAY_NAME>
would be good, but it's almost certainly not related to this bug.Is there an error shown when running Blender from the command line, when the shading errors show?
https://docs.blender.org/manual/en/latest/advanced/command_line/launch/macos.html
Most likely there is something in the shader code that is either non-standard, or or that triggers a bug in the macOS OpenGL driver.
This is the generated shader code, but I don't see anything particularly suspicious: P2852
Added subscriber: @LazyDodo
beyond a missing version directive and glslangValidator also sees nothing suspicious
{F12943140}Here I started blender from the Terminal, loaded my example scene and switched the Display Device from Rec.709 to sRGB
(base) daniel@iMac2020 MacOS % ./Blender
Color management: Using /Users/daniel/MEDIA/ACES/OpenColorIO-Config-ACES-0.2.0/config-aces-cg.ocio as a configuration file
Color management: Error could not find role color_picking role.
Color management: Error could not find role texture_paint role.
Color management: Error could not find role default_byte role.
Read prefs: /Users/daniel/Library/Application Support/Blender/3.2/config/userpref.blend
Color management: display "ACES" used by scene not found, setting to default ("Display - sRGB").
Color management: scene view "sRGB" not found, setting default "Output - SDR Video - ACES 1.0".
Read blend: /Volumes/Blue-Studio/TOODEE/TooDee - LUTchat/59_Roundabout_NP_Canon_7DMKII_360_HDRI/03_Cortijo_Salinas_Terraza/2022_Blender_320alpha_and_OCIO_v2_issue/Blender_32alpha_OCIOv2_sRGB_bug.blend
IMB_colormanagement_colorspace_to_scene_linear: perform conversion from unknown color space
OpenColorIO Error: Color space '<USE_DISPLAY_NAME>' could not be found.
Note that I don't really know how any of this works, but just trying to get anything out of the traiging process.
I am not sure if the issue is about the generated shader, since the issue also happens when saving the file, which I assume don't invoke the shader.
@DanielBrylka Not sure if this is related either, but can you define the role
default_byte
in the new configuration to one of the sRGB ones?First of all, I can only replicate the bug on my specific machine configuration. Mac's with AMD graphics got access to render via Metal in Blender with the macOS release 12.3.
Standard Blender works as expected. Only with the OCIO 2 config I run into this problem.
I am not aware how to define a role in the OCIO Config.
I made another screen capture to better illustrate the behavior.
Something got twisted with the Display -sRGB transform.sRGB_bug_screencapture.mov
If someone can tell me what to try next, I am happy to do it.
@DanielBrylka you can define Roles in the Config. It seems that the ACEScg config File in the non-modified form throws errors.
Maybe there could even be a chance to merge blender Filmic via Config to a single OCIOv2 Config.
I am not a OCIO professional and I don't see Blender Infos which roles are used inside blender except for the OCIO that ships with blender:
roles:
Internal scene linear space
Default color space for byte image
Default color space for float images
Default color space sequencer is working in
Distribution of colors in color picker
Non-color data
For interop between configs, and to determine XYZ for rendering
Specified by OCIO, not used in Blender
Can you check if this one works?
config-aces-cg.ocio
Added subscriber: @Nurb2Kea
When I use the ACES 1.2 Lut-folder and the config.ocio from Git, in blenders 'colormanagement' folder, it works fine.
//When I exchange the 1.2 ACES config.ocio with this config-aces-cg.ocio or the downloaded one form Git AND rename it to just config.ocio,
then blender starts to load and at the moment when the window want to come up, it quits.//
apple crash log blender.txt
But when I remove the following in the v2.0 config.ocio,, it starts up:
shared_views:
with this colormanagement:
Very limited...
Usually I'm getting this with ACES 1.2 :
config.ocio
Or am I getting something wrong with ACES OCIO!?
Please let's stay on the topic of this bug report, which is about wrong colors in viewport display. Any other issues should be reported separately.
This issue was referenced by
c65b022e62
Errors regarding
<USE_DISPLAY_NAME>
should be fixed now.Regarding the viewport issue on macOS + AMD, we were able to reproduce this but have no solution yet. It seems like a driver bug, and we did not yet find a workaround.
