If the user changes the OS terminal to one that cannot be hidden by its clients, then blender cannot hide it #96672
7 Participants
Reference: blender/blender#96672
Operating system: Win11 (also probably true on Win10)
Graphics card: 3090
Broken: 3.1
Worked: probably N/A
When Windows Terminal is set as the default terminal Blender will launch under it, but can't hide it - the terminal will always be visible and Window>Toggle System Console doesn't work.
Updated from Harleys comment - since Blender can't work with Windows Terminal and it breaks the use model and menu choice, change this to a request to have Blender only use the old style Windows terminal regardless of the default terminal.
Windows Terminal is a Microsoft replacement for the default cmd window, supporting tabs, settings and other advanced features.
Added subscriber: @DrMc
Added subscriber: @Harley
We currently have no solution to this design change by Microsoft.
We currently use the Windows API function
GetConsoleWindow
to get the console window handle so that we can show/hide it. Unfortunately this does not work when using virtual terminals like Windows Terminal. The Microsoft documentation on this function not only mentions that this will not longer work, but it "does not have a virtual terminal equivalent": https://docs.microsoft.com/en-us/windows/console/getconsolewindow.You can read more details about Microsoft's design decisions regarding this, with specific details about this issue specifically in the "Direct Window Access" section: https://docs.microsoft.com/en-us/windows/console/classic-vs-vt.
In a nutshell, virtual terminals can't be hidden by the applications they host.
Windows Terminal as default terminal, Blender can't control it (no toggling)to Blender Windows should ignore default terminal and always use cmdThanks for the informative reply Harley!
OK then, I updated the task to "Blender should only use the old style terminal, regardless of the preferences setting." Maybe there's a reason why that isn't easy, but since virtual terminals breaks Blender features Blender should just not allow use of Virtual terminals, and ignore the Windows preference.
Added subscriber: @mano-wii
I'm not sure if preventing Blender from using "Windows Terminal" would be an ideal solution.
I'm not familiar with what's involved in the blender console, but blender always showing it while in other applications doesn't really seem to be a problem.
So I'm confirming as a bug for now.
Blender Windows should ignore default terminal and always use cmdto Can't hide console when 'Windows Terminal' is set as the default terminal (instead of cmd)Added subscriber: @LazyDodo
we don't get to pick the terminal we launch in that's up to the OS, not sure why we would classify it as a blender bug as we have no control over this?
This report could be reworded to "If the user changes the OS terminal to one that cannot be hidden by its clients, then blender cannot hide it"
As I understand the problem is the fact that Blender always launch with a terminal.
Therefore the report could be described as:
"If the user changes the OS terminal to one that cannot be hidden by its clients, then blender always launches with an unrequested terminal"
If the solution is out of control, we can consider it a
.Known issue would be things inside our control but no one scheduled to work on for at least 6 months
Can't hide console when 'Windows Terminal' is set as the default terminal (instead of cmd)to If the user changes the OS terminal to one that cannot be hidden by its clients, then blender cannot hide itChange title to Harley's suggestion - the issue really being Blender has menu picks to hide the system console when it can't.
Not a significant issue obviously but worth having an issue for at any rate for the next time somebody is in that part of the code.
I don't think there is much we can do "next time somebody is in that part of the code". Even if we were to test for the situation and grey out the menu option we'd still get bug reports about why.
setConsoleWindowState
could maybe print out an error message to the console if it gets nothing fromGetConsoleWindow
, assuming that is what happens in this case, but not sure anyone would notice.In a nutshell your OS is giving you a new option. If you choose to use that by default then you lose some functionality in some programs, because of what features Microsoft has chosen to include in Windows Terminal. But they appear to be working on a fix... https://github.com/microsoft/terminal/issues/12570
Added subscriber: @Raimund58
@Harley
https://github.com/microsoft/terminal/issues/12570 was closed and marked as fixed... But is it fixed for Blender as well?
@Raimund58
That issue is our exact problem. In fact their "test case" -
::ShowWindow(::GetConsoleWindow(), SW_HIDE);
- exactly describes our usage.We've been following this issue - how Microsoft is handling this - for a while now. They came to the realization early that their changes broke a lot of usage and have been trying to come up with fixes that work but stay within their plans. That report was closed with a commit, but I've also seem some related reverts as it breaks some of their features. Regardless, the change would only be seen, for now, in something like Windows Terminal Preview , not in the general release of Windows 11 or in a Windows Update yet.
Rather than wait for Microsoft to fix this our current focus has been on the use of the
blender-launcher.exe
, which appears to solve this problem. However there are still some issues. For one the downloads from Windows store was not set to use that executable - I think this was recently fixed. And there are some issues to do with Taskbar Recents lists and if you select just "Blender" from the Taskbar jumplist it will launch the bare executable. @LazyDodo is working on that.Added subscriber: @Kuboa
hey guys I found a solution to the problem, if you change your default terminal profile to cmd in the terminal settings, the problem will go away
