Crashes with Intel GPUs - GPU shader compilation fails #96678
6 Participants
Reference: blender/blender#96678
Operating system: Windows 10
Graphics card: Intel i-9 12900K iGPU
Broken:
374cb32d4a
Worked:
2580869901
GLSL shader compilation fails with error message:
And then crash:
Open Blender
Load classroom scene
Added subscriber: @Stefan_Werner
Added subscriber: @Sirgienko
Added subscriber: @mano-wii
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Thanks for the report,
I suggest you use
Help -> Report a Bug
in Blender so there is complete information about the Blender version and graphics cards.(
"Graphics card: Intel i-9 12900K iGPU"
is not the information we would expect).But this hardware is recent and should be supported.
Since there is an error message (and it appears to be related to
374cb32
), I believe the report is valid and deserves to be forwarded to the #eevee_viewport team.Added subscriber: @Memento
system-info.txt
This should be addressed for the 3.2 release, otherwise the 3.2 release will crash on some machines with Intel graphics. (Blender dereferencing a NULL pointer from a failed shader compilation)
Looking at the code, all compute shaders have an
array
macro defined by default. See"#define array(_type) _type- [ ]\n"
in {https://developer.blender.org/diffusion/B/browse/master/source/blender/gpu/opengl/gl_shader.cc$843}And the shader named
"subdiv patch evaluation"
has some apparent "array" tokens in:{https://developer.blender.org/diffusion/B/browse/master/source/blender/draw/intern/shaders/common_subdiv_patch_evaluation_comp.glsl$251}
{https://developer.blender.org/diffusion/B/browse/master/source/blender/draw/intern/shaders/common_subdiv_patch_evaluation_comp.glsl$254}
{https://developer.blender.org/diffusion/B/browse/master/source/blender/draw/intern/shaders/common_subdiv_patch_evaluation_comp.glsl$260}
{https://developer.blender.org/diffusion/B/browse/master/source/blender/draw/intern/shaders/common_subdiv_patch_evaluation_comp.glsl$276}
{https://developer.blender.org/diffusion/B/browse/master/source/blender/draw/intern/shaders/common_subdiv_patch_evaluation_comp.glsl$282}
So... maybe if we undefine the macro
array
in the compute shader the problem is solved???Added subscriber: @PratikPB2123
Hi @Stefan_Werner, I'm also getting similar OpenGL error.
I've not loaded classroom scene on my system. But can you check if crash still occurs after turning Off the GPU subdivision?
Also check if you can reproduce crash as mentioned in #97449 (GPU subdivision: Crash on adding subdivision surface modifier)
I suspect both reports are identical :)
Closed as duplicate of #97449
