Density of volume shader doesn't change/react on input value #96795
Closed
opened 2022-03-26 11:00:32 +01:00 by Christoph Duyster · 9 comments
Operating system: macOS-12.1-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Max Apple 4.1 Metal - 76.3
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: f1cca30557
I try to change the density of my volume shader based on the distance of 2 objects.
So i have this GN node tree, which obviously works because the distance value is coming over as you can see if i plugin my shader:
But if i want to see my volume shader....it looks like a constant value. So maybe i am making a stupid mistake or it is a bug...
density_by_distance.blend
**System Information** Operating system: macOS-12.1-arm64-arm-64bit 64 Bits Graphics card: Apple M1 Max Apple 4.1 Metal - 76.3 **Blender Version** Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: `f1cca30557` Worked: (newest version of Blender that worked as expected) **Short description of error** [Please fill out a short description of the error here] **Exact steps for others to reproduce the error** [Please describe the exact steps needed to reproduce the issue] [Based on the default startup or an attached .blend file (as simple as possible)] I try to change the density of my volume shader based on the distance of 2 objects. ![image.png](https://archive.blender.org/developer/F12948040/image.png) So i have this GN node tree, which obviously works because the distance value is coming over as you can see if i plugin my shader: ![image.png](https://archive.blender.org/developer/F12948034/image.png) But if i want to see my volume shader....it looks like a constant value. So maybe i am making a stupid mistake or it is a bug... ![image.png](https://archive.blender.org/developer/F12948037/image.png) [density_by_distance.blend](https://archive.blender.org/developer/F12948030/density_by_distance.blend)
Added subscriber: @LuckyChris
#96521 was marked as duplicate of this issue
Member
Member
Added subscribers: @brecht, @lichtwerk
Member
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Member
You cant use face/vertex based information in a volume shader, can you?
The distance in a shader works if you are rendering this on the surface, yes, but not so if done in a volume.
Dont think this has anything to do with the fact this is coming from geometry nodes, same is true for regular textures or vertex colors.
I think this can be closed (@brecht: correct me if I am wrong).
You cant use face/vertex based information in a volume shader, can you? The distance in a shader works if you are rendering this on the surface, yes, but not so if done in a volume. Dont think this has anything to do with the fact this is coming from geometry nodes, same is true for regular textures or vertex colors. I think this can be closed (@brecht: correct me if I am wrong).
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
This is a limitation, there is no way to interpolate surface attributes into the volume. In the future there may be geometry nodes that help with that kind of thing, doing it at render time would be expensive.
Member
Added subscriber: @Mantissa
5 Participants
Reference: blender/blender#96795
