Same pattern looks different for Cycles and Eevee #96936
5 Participants
Reference: blender/blender#96936
Operating system: Windows-8.1-6.3.9600-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.1.1, branch: master, commit date: 2022-03-29 17:50, hash:
d91843f3b6
This is the difference
simplified file
pixels tiled1.blend
old file
pixels tiled.blend
I suppose the difference in Color Ramp or Noise node.
Added subscriber: @Vyach
Added subscriber: @iss
I can reproduce the difference, but it is not obvious which node causes this or whether this is caused by float precision. Do you know what node is problematic in this case?
So far this seems to be issue with noise texture node and scale input, when increasing / decreasing value slowly, one of renderer will update image in advance of another as if there was some offset.
Added subscriber: @lichtwerk
Seems to be the
Map Range
node (in particular: itsLinear
mode, all other modes seem to behave the same in Cycles & Eevee)Sorry, no, it is not only the Map Range node, even without it, it can be different
The pattern made so, that it reacts to tiny difference in Noise and in halftones, I will try to simplify example. Can`t catch where exactly the issue.
I made stepped result before map range. And with step less than 0.0008 I see difference. With step 0.0009 there is no difference.
Just place step after Noise like this
Looks like Color Ramp is more precise (forCycles) than Greater than node for example.
I made simplified file.
pixels tiled1.blend
Added subscribers: @OmarEmaraDev, @fclem
Adding @OmarEmaraDev has he already worked on some of theses issues in the past.
But as a general note, the ramp node is a bit implementation dependent. In EEVEE, we resort to a 257 px wide texture to evaluate the ramp if there is more than 2 nodes. The optimization for less than 3 nodes can make the result more precise as there is no texture involved. I am not sure what Cycles uses to evaluate ramps.
So I'm not even sure what is the expected behavior, the one from Cycles? or the one from EEVEE?
Cycles also use a 256-sized table for evaluating the color ramp but it doesn't provide optimized paths for 2 bands like EEVEE does as noted by Clement, which is why we get that difference here.
Since EEVEE's implementation is more accurate here, it would make more sense to adjust Cycles to match the optimized paths, if that is fine with the Cycles module.
As it so, i agree and i would prefer, as a user, to have higher precision.
Also i will check Foat curve. I have suspicion, that it lower precision (both renders)
Okay, I caught it!
Similar issue with float curve #98085 (Unchanged float curve changes result. Difference in Eevee and Cycles)
