Object data bounds improvements proposal #96968
2 Participants
Reference: blender/blender#96968
Problems
There are issues with the handling of bounding boxes currently that
result in performance problems, inconsistencies, and overly complicated code:
Bounding Box Definition
This implies that the bounding box wouldn't be copied from the evaluated object
back to the original. While this might require some changes, it should make for
clearer code in the end.
Caching
Since the existing bounds cache really refers to the geometry, it should be cached in
the geometry. Object bounds can be built out of the geometry bounds as necessary.
This should significantly speed up geometry instancing, where the bounds currently
need to be recalculated on every redraw.
Return By Value
Returning
BoundBox
by value when accessing object bounds can make it clear thatit's just built from the geometry bounds. It also makes it possible to remove the allocated
bounding box from
Object.runtime
.Implementation
Step 1: Geometry caching, internal changes
e8f4010611
e8f4010611
BoundBox
by value inBKE_object_boundbox_get
Bounds<float3>
) instead the full 8 cornersBKE_pointcloud_boundbox_get
andBKE_mesh_boundbox_get
) use the evaluated objectObject.runtime.bb
)Step 2: Python/RNA API
Step 3: Remove Syncing
Step 4: Potential Future Improvements
References
This issue was referenced by
e8f4010611
