Meshes vertex normals changed via Python API are not used by dupli vert instances #97018
5 Participants
Reference: blender/blender#97018
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash:
cc66d1020c
Worked: 3.0.1
Changing the normals of a mesh via the Python API (with mesh.vertices- [x].normal) does not modify the orientation of dupli vert instances placed on each vertex of that mesh. It assumed there are no edges nor faces, only verts for instances placement.
m = bpy.data.meshes['Plane']
m.vertices- [x].normal = 1,0,0
This bug makes it impossible to place lots of instances objects in a scene using only vertices, I use it a lot.
Added subscriber: @piiichan
Added subscriber: @OmarEmaraDev
This doesn't seem to be working either on 3.0 using the blend file you provided. No matter what I assign to the normal, it is always
Vector((-0.7070833444595337, -0.7070833444595337, 0.0))
. Should I have done something differently?Here is a video that shows that for me assigning a normal does change its value, but not in the viewport.
demo.mp4
In Blender 3.0, true it is the same behavior using this method, but if you create a complete new mesh with Python, it works. Using the same demo .blend file, type in the Python console:
m = bpy.data.meshes.new("new_mesh")
m.from_pydata(vertices=[(1,0,0)], edges=- [ ], faces=[])
m.vertices- [x].normal = 0,0,1
Then swap the plane mesh with the newly created one, and the corresponding dupli vert instance will be rotated.
In the end, both ways should work.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
I can replicate a change in the behavior across versions. In 3.0, changes to vertex normals take effect but are overwritten later, when going to edit mode for instance. In 3.1, changes to normals are written, but do not take effect at all.
Tried
BKE_mesh_vertex_normals_clear_dirty(mesh);
inBKE_mesh_vertex_normals_clear_dirty(mesh);
, but that didn't work. The original behavior is suspicious to me, so tagging the module for more information.Yes going to edit mode erases all vertex normals set via Python. This behavior goes way back to... I don't know... blender 2.49 at least. The best solution would be: custom vertex normals take effect AND going into edit mode doesn't erase them.
Added subscribers: @HooglyBoogly, @EAW
This was changed in 3.1 in the moving of normals out of MVert. See:
cfa53e0fbe
See the Python_API release notes here:
https://wiki.blender.org/wiki/Reference/Release_Notes/3.1/Python_API
In
b7fe27314b
, there is the note:@HooglyBoogly do you have a suggested workaround?
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
Added subscriber: @Hans-6
Setting the normal was always problematic and should never have been possible, since many operations would overwrite them anyway. Vertex normals are derived data, not something that's meant to be editable by the user.
I'd suggest using a vector attribute and the geometry nodes instance on points node for creating instances.
So, I don't think this is a bug, just a weird part of the Python API.
I see, I'll try the geometry nodes alternative, thank you.
The vertex normal attribute should be made read-only in the Python API, to avoid confusion for users.
Thanks, good idea. I did that here:
891268aa82
Great! :)
