Keyboard shortcuts not working in multi window setup #97121
Closed
opened 2022-04-06 19:59:21 +02:00 by Sampo Ukkola · 17 comments
Operating system: macOS-12.3.1-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Max Apple 4.1 Metal - 76.3
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: cc66d1020c
Blender shortcut keys do not work after shit drag window duplication
what does not work:
keyboard shortcuts do not work in the source window where the new window was created from after new window is created.
if the new window is closed the shortcuts work again in the source window
what works:
creating a new window from window menu results into shortcuts working in both windows
  1. shift drag a new window from blender 3d viewport window
  2. move new window out of the way
  3. drag cursor on the old/first window 3d viewport
  4. press shift+a
  5. context menu will not appear
**System Information** Operating system: macOS-12.3.1-arm64-arm-64bit 64 Bits Graphics card: Apple M1 Max Apple 4.1 Metal - 76.3 **Blender Version** Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: `cc66d1020c` Worked: (newest version of Blender that worked as expected) **Short description of error** Blender shortcut keys do not work after shit drag window duplication what does not work: keyboard shortcuts do not work in the source window where the new window was created from after new window is created. if the new window is closed the shortcuts work again in the source window what works: creating a new window from window menu results into shortcuts working in both windows **Exact steps for others to reproduce the error** 1. shift drag a new window from blender 3d viewport window 2. move new window out of the way 3. drag cursor on the old/first window 3d viewport 4. press shift+a 5. context menu will not appear
Author
Added subscriber: @tabongobong
#97236 was marked as duplicate of this issue
Added subscriber: @mano-wii
I'm not sure what you mean by "drag cursor on the old/first window 3d viewport".
Note that if a window is not active, it is normal for keyboard shortcuts not to work.
You need to activate the window first by clicking on it for the shortcuts to work.
Does what I said make sense to you?
I'm not sure what you mean by "drag cursor on the old/first window 3d viewport". Note that if a window is not active, it is normal for keyboard shortcuts not to work. You need to activate the window first by clicking on it for the shortcuts to work. Does what I said make sense to you?
Author
The shortcuts will not work in either case. With ot without clicking it first. Whether the window is clicked or not and the practically the shortcut keys will not work.
The same functionality from the menu does not need a click in neither one of the windows before shortcuts work. Dragging the cursor to the window and pressing shortcut key seems to work
The shortcuts will not work in either case. With ot without clicking it first. Whether the window is clicked or not and the practically the shortcut keys will not work. The same functionality from the menu does not need a click in neither one of the windows before shortcuts work. Dragging the cursor to the window and pressing shortcut key seems to work
Member
Added subscribers: @jean-martin-barbut, @PratikPB2123
Added subscriber: @iss
Does this issue happen when you drag new/old window to external monitor? I think I saw some issue like that. Also can you check if this issue is specific to Mac machines?
Member
@tabongobong , could you confirm if this is the requirement for replicating the issue?
> Does this issue happen when you drag new/old window to external monitor @tabongobong , could you confirm if this is the requirement for replicating the issue?
On 3.1.2, on my system, yes it happens when I move the new window on external monitor, working fine on 3.2
> In #97121#1370182, @PratikPB2123 wrote: >> Does this issue happen when you drag new/old window to external monitor > @tabongobong , could you confirm if this is the requirement for replicating the issue? On 3.1.2, on my system, yes it happens when I move the new window on external monitor, working fine on 3.2
Member
@esox_13- On 3.1.2, on my system, yes it happens when I move the new window on external monitor, working fine on 3.2
Thanks for the information. Will wait for @tabongobong's reply before closing this ticket
>@esox_13- On 3.1.2, on my system, yes it happens when I move the new window on external monitor, working fine on 3.2 Thanks for the information. Will wait for @tabongobong's reply before closing this ticket
Member
@tabongobong hi, could you verify please?
> On 3.1.2, on my system, yes it happens when I move the new window on external monitor, working fine on 3.2 @tabongobong hi, could you verify please?
Member
Member
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
6 Participants
Reference: blender/blender#97121
