Import USD materials that are not assigned to any object #97195
6 Participants
Reference: blender/blender#97195
Operating system: macOS-12.3-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 580 OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.8.13
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash:
cc66d1020c
Worked: N/A
Failed to import a simple .usda and .usdc file with only 1 default prim defined (and it is a material).
However, it is possible to use a third party importer such as: https://github.com/robmcrosby/BlenderUSDZ
I do not see why Blender cannot handle the .usda file natively.
Added subscriber: @Zhen-Dai
Blender was able to import material if the usda contains a dummy mesh, such as this one: https://ambientcg.com/view?id=PavingStones115A
But it also set
st
as uv map incorrectly on the material.(Since there is no vertices in the mesh, the uv map is also empty, setting
st
will never work anyway, not sure how this should be handled.)(In the meantime, BlenderUSDZ add-on will hang on this file if imported usdz, so fun time for everyone facing this.)
Additional point (but not strictly a bugfix): Blender usd importer could have supported
displacement
andocclusion
map, but it didn't for reasons?https://graphics.pixar.com/usd/release/spec_usdpreviewsurface.html#preview-surface
Added subscribers: @makowalski, @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
This bugtracker will only handle the native importer, so please no reports about third party Addons.
Can confirm the behavior, no materials are created without dummy objects.
(This is a bit in line with other format importers though, not sure if there is any that just imports materials)
So this might be more like a feature request (a good one though), so maybe @makowalski has this on the TODO already? Or wants to keep this as TODO?
Blender 3.1 does not import USD materialto Blender 3.1 does not import USD material (without a dummy object)Thanks for reporting this, @zhendai. I agree that this is a good feature request and will investigate. We can probably add an option to import unassigned materials, or something similar.
I'm also investigating importing
displacement
andocclusion
, which can be addressed as a separate task.Thx, recently Node Wrangler add-on added similar support as well:
https://developer.blender.org/D14134
Blender 3.1 does not import USD material (without a dummy object)to Import USD materials that are not assigned to any objectAdded subscriber: @codeloadgame
Added subscriber: @Lennart-Demes
As the creator of ambientCG I would like to say Thanks! When I initially generated all the 1500+ USD files for the website Blender's USDPreviewSurface support was still very limited in general, so I assumed the feature would follow at some point. It's great to see this issue acknowledged.
To help with testing I have prepared some sample files with and without a dummy object on Google Drive .
I just tested these files in the latest 3.3.0-alpha(blender-3.3.0-alpha+master.dfb8c90324c0-windows.amd64-release) and can confirm that only the version with the dummy object gets the material imported, even when disabling the "visible objects only" checkbox while importing.
There is also a DevTalk thread about this, in case someone wants to discuss this situation and possible solutions there instead.
Thank you so much for the feedback, @struffel. Indeed, importing unassigned materials is a desirable feature, as I noted above, and I'm about to start work on this. Your files will serve as a good test case, so thank you for providing them!
Hi, it's been a while. Has there been any recent activity regarding this topic, maybe in one of the daily/bleeding edge builds?
Hi @Lennart-Demes This task was partly blocked by unrelated refactoring of the USD material import code, which is now done. I'll be working on the "unassigned materials" import topic next.
@Zhen-Dai @Lennart-Demes I've implemented this feature and it's available for you to test in the
tmp_usd_import_unbound_mtls
experimental build available from the experimental builds downloads page:https://builder.blender.org/download/experimental/
There is a new
Unbound Materials
toggle to enable importing unassigned materials, which is off by default. You will probably need to rename the mesh UV set to match what's expected by the material, usuallyst
.I will create an official patch for this later today. Please let me know if you have feedback or encounter issues.
Thx Michael! Downloading now, I will test it out this Friday.
Super exciting! I'll test it out tomorrow!
Okay, looks good to me! All the materials are getting imported.
The thing with the UV map name is a bit annoying of course but I don't see a way of dealing with that without creating issues elsewhere (I could rename my UV maps to Blender's 'UVMap' default name instead of 'st' but that would break stuff for other people).
Thanks so much for testing, @Lennart-Demes!
As for the UV map name issue, we could add an option to automatically rename the maps on import into Blender. E.g., a checkbox to rename
st
toUVMap
, or more generally, some sort of UI to specify how USD primvars should be renamed when converting to Blender attributes. But this will require some thought and discussion, so it should probably be handled in a separate patch.Hi again, this feature hasn't made the jump into the official 3.4 release, has it? Is it possible to say with which official release the new material import will be shipped?
Hi Lennart. Sorry for the late reply. I'm still addressing some issues raised in the patch review and I hope to have a revision for this some time next week. Therefore, this feature has not been merged into 3.4, but I believe it will ready for 3.5, barring any unexpected issues in subsequent reviews.
Hi @Lennart-Demes and @zhendai. Just FYI, I submitted a revision to the patch based on the reviews. I also created a patch build for this latest version. If you want to try it, please go to
https://builder.blender.org/download/patch/
and look for the D16172 build. Note that the USD import option for this feature is now called
Import All Materials
.Looks good to me! I tried the usda and usdc files of these materials:
ambientCG.com/a/PavingStones036 (base case)
ambientCG.com/a/ManholeCover004 (metalness and opacity)
ambientCG.com/a/Lava005 (emission)
and they all worked as expected.
Thanks for testing, @Lennart-Demes!
Added subscriber: @GregZaal
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
@Zhen-Dai @Lennart-Demes This change has landed in master and should be available in the next alpha build.
That's amazing! Thank you!
