Rename to Remove Named Attribute node #97512
6 Participants
Reference: blender/blender#97512
Testing this out, the name looks almost absurdly long to me.
In the end I'm not really convinced that the consistency benefit of having "Named" in all three nodes is worth the ugliness of the wide node, especially when "Named" doesn't clarify much in this case, since only named attributes can be removed.
I wonder what others think, or if people care about the wideness.
{F13014815 size=full}
Added subscriber: @Rawalanche
I vote for the first option - creating the node at the same width as others, and just truncating the end of the name. "Attr" ends up being a really good abbreviation.
Having random node widths destroys aesthetic, but at the same time, if there's a set of nodes containing the term "named attribute", then it should be used consistently everywhere, so that new users get the implication this set of nodes is meant to be used together.
Once one is familiar with the basic concepts, the name "Remove Attribute" may be a bit confusing, since it may imply also ability to remove built in attributes, or that it's a naming bug/mistake.
We talked about this a bit more in the submodule meeting today-- people preferred the second option, making the node wider as necessary to fit the name by default.
I don't think people are that thrilled by the need to use "Named" at all here, but this should at least be consistent with the other two nodes, and the naming needs to be different from "Capture Attribute" somehow.
This issue was referenced by
2fd8fa8f84
Added subscriber: @mod_moder
Can this option be considered more general for nodes that work with text identifiers?
2022-09-04 01-54-14.mp4
The logic is that if nodes work with text identifiers (that is, in the name now we say in the name that this is an attribute name), then it would be more convenient to output the identifier as a name, so that the user can choose the length of the node himself.
This is my quick example of this
P3170
Hmm, I don't think we should label nodes dynamically like that. It's mixing "instructions" with "data" in a way that isn't separated clearly like the existing overlays and warnings.
It works okay in that situation, but in more complicated cases I think it would give us trouble.
Added subscriber: @Erindale
My 2 cents is you don't need to see the node label all the time. You just added the node so you know what you're getting. All nodes should be a common width. The UI inconsistencies in Blenders nodes is already extremely frustrating for keeping graphs tidy like how node sockets don't match to grid and UI scaling is different between grid and nodes which leads to further offsetting.
This is something I want to see when nodes are collapsed as you only see the header. Similarly for Object info nodes, they should display the name of the object when collapsed instead of "Object Info" which at that point is not useful.
