Sculpt & Pbvh Drawing Speedup #97665
2 Participants
Reference: blender/blender#97665
Problem overview:
Sculpted meshes are drawn as little chunks of geometry. Each leaf node inside the PBVH (sculpt acceleration structure) produces one draw call with a dedicated vertex buffer. These leaf nodes are currently frustum culled on CPU for each draw pass.
The main issues are:
1 - CPU culling overhead of high leaf nodes counts. Not a real problem but if we want better culling, higher node count will help.
2 - No advanced culling of completely facing away leaf nodes.
3 - Driver overhead caused by high VAO/VBO switching. Also sub-optimal data layout for transfer.
4 - Overhead of using flat normals (cannot shared vertices between tris).
Proposed improvements:
1 - Port culling on the GPU using compute and multi indirect drawcalls. Could cull subpixel nodes if they are not visible.
2 - Use visible cone culling [TODO add link to resource here]. The cone could be computed by a compute shader and cached.
3 - Merge all VBOs into 1 that can be updated using range mapping. Simplify data layout.
4 - Implement a global fallback in fragment shader when
N == vec3(0)
to useNg
(geometric normal generated from derivatives).Note that all these are independent from each others and can be implemented in any order.
Requirements:
1 - Requires that we wrap a
GPUDrawList
buffer inside a GPUBatch. This way the draw is issued on CPU but computed on GPU.2 - Have the same requirements as 1.
3 - Implement mapping with range in VBO/IBO.
4 - No requirements.
Further investigation:
is the better solution for my opinion.
