Extremely Long time delay using geometry nodes with simple mesh boolean node 37706ms #98020
Closed
opened 2022-05-10 17:18:04 +02:00 by RT · 9 comments
Operating system: Linux-5.13.0-41-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: Mesa DRI Intel(R) HD Graphics 4600 (HSW GT2) Intel Open Source Technology Center 4.5 (Core Profile) Mesa 21.2.6
Broken: version: 3.2.0 Beta, branch: master, commit date: 2022-05-10 06:30, hash: 11aa237858
Extremely Long time delay using geometry nodes with simple mesh boolean node and difference (it takes 37706ms for the mesh boolean node to do a cylinder difference)
I've included the blend file which shows the times when you change the item to do a boolean difference 1 cylinder/count to 2 cylinder/count.
When I use the Boolean Modifier this time lag doesn't occur. I've included this in the blend file for testing also.
PS: this time lag also occurs in Blender 3.1.2
prego lid gn.blend.zip
**System Information** Operating system: Linux-5.13.0-41-generic-x86_64-with-glibc2.31 64 Bits Graphics card: Mesa DRI Intel(R) HD Graphics 4600 (HSW GT2) Intel Open Source Technology Center 4.5 (Core Profile) Mesa 21.2.6 **Blender Version** Broken: version: 3.2.0 Beta, branch: master, commit date: 2022-05-10 06:30, hash: `11aa237858` Worked: (newest version of Blender that worked as expected) **Short description of error** Extremely Long time delay using geometry nodes with simple mesh boolean node and difference (it takes **37706ms** for the mesh boolean node to do a cylinder difference) **Exact steps for others to reproduce the error** I've included the blend file which shows the times when you change the item to do a boolean difference 1 cylinder/count to 2 cylinder/count. **When I use the Boolean Modifier this time lag doesn't occur**. I've included this in the blend file for testing also. **PS: this time lag also occurs in Blender 3.1.2** ![screenshot-May-10-2022-11-06-57.png](https://archive.blender.org/developer/F13064931/screenshot-May-10-2022-11-06-57.png) [prego lid gn.blend.zip](https://archive.blender.org/developer/F13064941/prego_lid_gn.blend.zip)
Author
Added subscriber: @Still
Member
Added subscriber: @OmarEmaraDev
Member
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Member
This looks unreasonable indeed especially when compared to the modifier which I guess do the same thing. But the performance analysis seems normal as far as I can see, so tagging the module for more information.
This looks unreasonable indeed especially when compared to the modifier which I guess do the same thing. But the performance analysis seems normal as far as I can see, so tagging the module for more information. ![20220511-093136.png](https://archive.blender.org/developer/F13067086/20220511-093136.png)
Added subscriber: @AntonioPuentes
Maybe the boolean is being computed once per instance. Putting a relize instances node is only computed on a single mesh.
Maybe the boolean is being computed once per instance. Putting a relize instances node is only computed on a single mesh. ![Screenshot_20220512_195212.png](https://archive.blender.org/developer/F13071205/Screenshot_20220512_195212.png)
Member
@AntonioPuentes But there are only two instances and a boolean modifier with two cylinders is also very fast. So why would the node take orders of magnitude higher execution time?
My fault, it seems that with relize instance node, the boolean is not being calculated correctly.
Probably the problem is with the geometry connected to the input "Mesh 1". The boolean node is calculating the difference of the geometry connected to the input socket "Mesh 1"
My fault, it seems that with relize instance node, the boolean is not being calculated correctly. {[F13072093](https://archive.blender.org/developer/F13072093/Screenshot_20220513_094112.png)}![Screenshot_20220513_094247.png](https://archive.blender.org/developer/F13072095/Screenshot_20220513_094247.png) Probably the problem is with the geometry connected to the input "Mesh 1". The boolean node is calculating the difference of the geometry connected to the input socket "Mesh 1" ![Screenshot_20220513_100117.png](https://archive.blender.org/developer/F13072135/Screenshot_20220513_100117.png)
Philipp Oeser removed the
label 2023-02-10 08:44:03 +01:00
Member
There is ongoing work to implement a faster boolean: #114476
Also the "fast/non-exact" boolean mode should be exposed in the node in 4.2.
But the performance of the current boolean exact mode is expected, it can often be quite bad.
There is ongoing work to implement a faster boolean: #114476 Also the "fast/non-exact" boolean mode should be exposed in the node in 4.2. But the performance of the current boolean exact mode is expected, it can often be quite bad.
Blender Bot added
and removed
labels 2024-03-07 16:45:32 +01:00
Reference: blender/blender#98020
