VSE: Adjustment Layer create new image #98057
5 Participants
Reference: blender/blender#98057
Graphics card: NVIDIA GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.39
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash:
cc66d1020c
Adjustment Layer create new image that is moved and i think maybe many things is affected by the same bug if they use same principal of work
2022-05-11 23-00-34.mp4
(( i notice when we apply for example glow effect to sth it affect all chosen resolution and not the actual size of the image 'scaled or not' so also moving the image make the the effect reapplied more performance issue happen ......))
2022-05-11 23-07-18.mp4
i'm not a programmer but that maybe is due to a temporary image get created every time basic changes like position or others happen
this image has the resolution of output and not the image also the temporary image is fixed and deosn't transforme informations from original image .... maybe my thinking has no sens about how things is working in vse..
ADJUSTMENT LAYER .blend
Added subscriber: @hamza-el-barmaki
Added subscriber: @OmarEmaraDev
According to the documentation:
So you are correct in saying that the adjustment layer create a new image by compositing the strips under it. The newly created image is then considered as a normal imported image which can be used as a strip for processing and editing.
VSE can also skip transformations if they have no effect when rendering strips, so that's why there might be a performance difference.
Is this is the answer you were looking for?
I @OmarEmaraDev
as i now adjustment Layer change values options in strip (sidebar) to all strips below adjustment layer and not create a temporary image ( i 'm not a programmer and don't know how things work in the background but if Adjustment layer create image then the original images must be hidden and sidebar show only options of temporary image in order to play as we like )
here a video show effect expected
https://www.youtube.com/watch?v=pIRkDheGsv8 starts 2.15
https://www.youtube.com/watch?v=RJOyzqahDow starts at 1:30
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscriber: @iss
So the issue is that strips that were rendered into the input of the adjustment strip are still visible, but you expect them to no longer be rendered because they are now represented by the adjustment strip.
Not sure about this behavior, so tagging the module for more information. Maybe @iss can take over this report.
@hamza-el-barmaki Actually, can't you just change the blend mode of the adjustment strip to be Replace?
your right it works thank you very much.... helpful team..
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
Good to hear.
Since this have no performance implications and multiple options are given, we can archive this.
Added subscribers: @Sergey, @tintwotin
Though the issue here can be fixed by changing blend mode, it is very likely other users will encounter the same problem and report it again as a bug. If the ambition of the VSE is that "it should just work", then the default blend mode for Adjustment Layer should probably be Replace.
This problem was introduced when the default blend mode was recently changed for all strips, and the mentioned problem wasn't taken into account. Actually, more strips may be negatively be affected by this change of the default blend mode ex. Multicam strips should properly not be Alpha Over either.
When Blende Mode defaults were changed the specification of Adjustment Layer using Cross as Blend mode was removed - and it shouldn't: https://developer.blender.org/D12952
I would say that this is a regression. IMO, @Sergey or @iss should have a chance to reflect on this report before it is closed. @OmarEmaraDev could you open the report again?
Changed status from 'Archived' to: 'Needs Developer To Reproduce'
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
I agree that this was not great change, so will consider this as a bug.
This issue was referenced by
8eda776eef
