ValueError: WorkSpaceTool.setup(): error with keyword argument "options" - : 'REGISTER' not found in ('KEYMAP_FALLBACK') #98109
Closed
opened 2022-05-14 04:38:21 +02:00 by liyiyi · 7 comments
macOS m1
Python: Traceback (most recent call last):
File "/Applications/Blender.app/Contents/Resources/3.1/scripts/startup/bl_operators/wm.py", line 2119, in execute
  if fn(context, space_type, self.name, as_fallback=self.as_fallback):
File "/Applications/Blender.app/Contents/Resources/3.1/scripts/startup/bl_ui/space_toolsystem_common.py", line 1088, in activate_by_id
  _activate_by_item(context, space_type, item, index, as_fallback=as_fallback)
File "/Applications/Blender.app/Contents/Resources/3.1/scripts/startup/bl_ui/space_toolsystem_common.py", line 1037, in _activate_by_item
  tool.setup(
macOS m1 Python: Traceback (most recent call last): ``` File "/Applications/Blender.app/Contents/Resources/3.1/scripts/startup/bl_operators/wm.py", line 2119, in execute if fn(context, space_type, self.name, as_fallback=self.as_fallback): File "/Applications/Blender.app/Contents/Resources/3.1/scripts/startup/bl_ui/space_toolsystem_common.py", line 1088, in activate_by_id _activate_by_item(context, space_type, item, index, as_fallback=as_fallback) File "/Applications/Blender.app/Contents/Resources/3.1/scripts/startup/bl_ui/space_toolsystem_common.py", line 1037, in _activate_by_item tool.setup( ``` ValueError: WorkSpaceTool.setup(): error with keyword argument "options" - : 'REGISTER' not found in ('KEYMAP_FALLBACK') location: <unknown location>:-1
Author
Added subscriber: @cvtutu
Author
import bpy
class OBJECT_MT_OpenCVPanel(bpy.types.WorkSpaceTool):
  """Creates a Panel in the Object properties window"""
  bl_label = "OpenCV Animation"
  bl_space_type = 'VIEW_3D'
  bl_context_mode = 'OBJECT'
  bl_idname = "ui_plus.opencv"
  bl_options = {'REGISTER'}
  bl_icon = "ops.generic.select_circle"
  def draw_settings(context, layout, tool):
      row = layout.row()
      op = row.operator("wm.opencv_operator", text="Capture", icon="OUTLINER_OB_CAMERA")
def register():
  bpy.utils.register_tool(OBJECT_MT_OpenCVPanel, separator=True, group=True)
def unregister():
  bpy.utils.unregister_tool(OBJECT_MT_OpenCVPanel)
if name == "main":
  register()
import bpy class OBJECT_MT_OpenCVPanel(bpy.types.WorkSpaceTool): ``` """Creates a Panel in the Object properties window""" bl_label = "OpenCV Animation" bl_space_type = 'VIEW_3D' bl_context_mode = 'OBJECT' bl_idname = "ui_plus.opencv" bl_options = {'REGISTER'} bl_icon = "ops.generic.select_circle" ``` ``` def draw_settings(context, layout, tool): row = layout.row() op = row.operator("wm.opencv_operator", text="Capture", icon="OUTLINER_OB_CAMERA") ``` def register(): ``` bpy.utils.register_tool(OBJECT_MT_OpenCVPanel, separator=True, group=True) ``` def unregister(): ``` bpy.utils.unregister_tool(OBJECT_MT_OpenCVPanel) ``` if __name__ == "__main__": ``` register()
Added subscriber: @rjg
Thank you for your report. Unfortunately, it does not contain the requested information that we need to investigate the issue. Please read this guide , it may help you write a bug report that allows us to identify the cause of the problem.
If you need help developing a Blender add-on, please post a question on one of our [community websites ]], for instance https:*blender.stackexchange.com/ , https:*blenderartists.org/ or the [ https:*blender.chat/channel/python | #python channel on Blender chat . The bug tracker is only for bug reports.
In case you believe that you've found a bug, please create a new bug report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template . Please provide system information (operating system, GPU, graphics driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
Thank you for your report. Unfortunately, it does not contain the requested information that we need to investigate the issue. Please read [this guide ](https://wiki.blender.org/wiki/User:Rjg/HowToBugReport), it may help you write a bug report that allows us to identify the cause of the problem. If you need help developing a Blender add-on, please post a question on one of our [community websites ]], for instance [[ https:*blender.stackexchange.com/ | Blender's Stack Exchange ]], [[ https:*blenderartists.org/ | blenderartists.org ]] or the [[ https:*blender.chat/channel/python | #python channel on Blender chat ](https:*www.blender.org/community/). The bug tracker is only for bug reports. In case you believe that you've found a bug, please create a new bug report through *Help > Report a Bug* in Blender. We expect all bug reports to follow the [submission template ](https://developer.blender.org/maniphest/task/edit/form/1/). Please provide **system information** (operating system, GPU, graphics driver version), **affected Blender version**, previous **Blender version that worked properly**, a **short and precise description of the issue**, step by step **instructions to reproduce it** and, if relevant, **a minimal .blend file that showcases the problem**.
Added subscriber: @czari
Hey, I've same issue and cant find any solution? Did you solve it?
Reference: blender/blender#98109
