Regression: Cannot select and move multiple nodes in Shader Editor (Industry compatible keymap) #98145
6 Participants
Reference: blender/blender#98145
Operating system: macOS-10.15.7-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro Vega II OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.10.23
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-05-14 17:46, hash:
139a4b6a84
and version: 3.2.0 Beta, branch: master, commit date: 2022-05-13 16:05, hash:074c695a0d
Worked: Blender 2022-05-08 daily builds (3.3.0 2022-05-08 and 3.2.0 2022-05-08)
Caused by
4c3e91e5f5
In Shader Editor with Industry compatible keymap: select two or more nodes and try to move them, only the node under your mouse will move instead of all selected nodes.
The problem also appears to happen with the compositing node tree and geometry nodes.
Video:
Added subscriber: @klu
Hi, thanks for the report. I'm not able to reproduce this in current master (
124aae91e226984016aa3482f849d8bbebbb3fa3
)I may have not understood the exact steps. How you are moving selected nodes? With key G? or mouse dragging?
How you are selecting these nodes? Box select, shift select? I'm not able to repro in either way.
If possible, please upload a screen recording demonstrating the exact issue.
Also check if you confirm the issue in uploaded file
#98145.blend
Hello -- thank you for your quick response. I was using mouse dragging with either Box select or shift select, and I do see that it is working OK if I press the G key first, so it appears to only be a regression with the additional mouseDown click.
Using the #98145.blend you provided, attached please find two screencasts showing the issue with shift or box select and then trying to move with the mouse (with the additional mouseDown click). It worked fine in 3.3.0_Alpha_master_2022-05-07, but it is no longer working in 3.3.0_Alpha_master_2022-05-14 (again using the G key does work):
Broken_3.3.0_Alpha_master_2022-05-14_rB139a4b6a844f.mov
Working_3.3.0_Alpha_master_2022-05-07_2a2261d7e193.mov
Hello again, I just downloaded the latest 2022-05-16
7fc2804f45
build from https://builder.blender.org/download/daily/ and I'm confirming that I still see the regression when using a mouse to box select and then move (without hitting G first). Again, this was working fine in the 2022-05-08 build and earlier.Broken_3.3.0_Alpha_master_2022-05-15_7fc2804f45af.mov
Thanks for the information. Still not able to replicate. Video: F13077557
I'll ask other triagers if that can reproduce
Added subscriber: @LazyDodo
no repro on windows either, maybe there's a plugin interfering? does it happen when you start with factory defaults?
Added subscriber: @lichtwerk
Also cannot repro here
Please try with File → Defaults → Load Factory Settings to see if you still can reproduce this issue.
Or it is the same as #97386 which was fixed last Friday, so testing a fresh build from https://builder.blender.org/download/daily/ would also help?
Hi all -- it looks like it may be something with key mapping. If I reset to factory defaults, it works. However, if I change to another keymap, the regression appears to be introduced. Here is a screencast starting with factory defaults and the Blender keymap. If I switch to the Blender 27x keymap, it breaks. If I switch to the Industry Compatible keymap, it breaks. If I switch back to the Blender keymap, it works again. In version: 3.3.0 Alpha, branch: master, commit date: 2022-05-07 04:41, hash:
2a2261d7e1
, it works with all three keymaps (and custom keymaps), so the regression occurred sometime after that build.T98145_Change_Key_Maps.mov
Thanks for the update. I'm able to confirm with industry compatible keymap.
Checking...
Added subscriber: @ideasman42
Caused by
4c3e91e5f5
@ideasman42 ^
Regression: Cannot select and move multiple nodes in Shader Editorto Regression: Cannot select and move multiple nodes in Shader Editor (Industry compatible keymap)This issue was referenced by
f68fb81064
