Many Geometry Node instances slow Cycles rendered viewport down (but only in camera view, perspective is fine) #98257
Reference: blender/blender#98257
windows 10
rtx 2080 ti
broken in Blender 3.1
works in ?
In scenes with many scattered objects, there is a huge difference in performance when in cycles rendered viewport, camera view vs perspective view.
Usually, I think the best way to view such scene, with a lot of scattered objects, is through cycles, with the overlay and gizmos turned off (gpu) as it´s less lag compared to solid view . But, if I switch from perspective to camera view it gets as laggy as if with overlay on/solid shade.
I´m not sure if this is a bug or a limitation but, Sins the perspective view and cam view is visually identical I report this as it would be a lot easier to be able to interactively work in camera view.
Open the attached file and set both perspective view and camera view to rendered se the difference in performance.
note: If you use a
Realize Instances
node just before outputting the geometry, the lag goes awayBug_Slow_Camera_VS_Perspective.blend
Added subscriber: @Dawe69
Added subscriber: @lichtwerk
Looks like this is actually the geometry nodes modifier being calculated.
If you use a
Realize Instances
node just before outputting the geometry, the lag goes awayChanged status from 'Needs Triage' to: 'Confirmed'
Will confirm for now (since I cant make sense of it atm).
Slow camera viewport update - cyclesto Many Geometry Node instances slow Cycles rendered viewport down (but only in camera view, perspective is fine)Closed as duplicate of #92233
