Issue with hold split in video sequencer, it duplicates the sequence before. #98265
Reference: blender/blender#98265
Operating system: Windows-10-10.0.19044-SP0
Graphics card:
renderer: 'NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2'
vendor: 'NVIDIA Corporation'
version: '4.5.0 NVIDIA 512.59'
version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash:
cc66d1020c
, type: releasebuild date: 2022-03-31, 23:39:57
When using hold split in video sequencer, it duplicates the sequence part behind the cut in front of the cut. When undo the action and redo it again, it works as indented.
I made a gallery , portraying the issue, since I'm bad at explaining.
Open Blender, Video Editing, drag video file into Sequencer and use hold split, it happens every time on every file.
Added subscriber: @Deckelmouk
Issue with hold split in video sequencerto Issue with hold split in video sequencer, it duplicates the sequence before.Added subscriber: @OmarEmaraDev
If I hold split a sequence at frame 22, the start of the second strip will have frame 18 as its first frame, then it continues normally starting from 22.
Added subscriber: @iss
Changed status from 'Confirmed' to: 'Needs User Info'
@OmarEmaraDev @Deckelmouk I can't reproduce this issue, can you provide .blend file where this happens?
I would assume this is issue with cache since it can't be reliably reproduced, but it shouldn't happen to my knowledge.
Reopening the file fixes the issue, so it seems to be a cache issue indeed.
Adjusting any property invalidates the cache and also fixes the issue.
20220524-114921.mp4
Can you provide video file? I can't reproduce still. Could be ffmpeg issue as well.
2022-05-25 00-41-47.mp4
Seems to happen with many files, but here is this particular one.
AN_Reaction_Diffusion.mp4
Sorry, lost track of this issue and forgot to check. I have tried now with 3.1.2 and 3.3, unfortunately I was still not able to reproduce.
@OmarEmaraDev Can you run blender with --debug-ffmpeg argument and paste output when you see incorrect frame?
This is what gets logged when I do the slice.
The only lines that are red (errors?) are:
Thanks for logs. Yes, that is the problem I was suspecting. I have fix for this, but it is sitting for quite long time so will have to go over code again to see if it is ready to go, then poke reviewers.
Will merge report to existing one.
Closed as duplicate of #86361
