Regression: Physics force field strength affect varies inversely proportion to physics substeps per frame #98272
5 Participants
Reference: blender/blender#98272
Operating system: Windows 10 Enterprise
Graphics card: Nvidia Quadro RTX 4000
Broken: 3.1.0 (same in 3.3.0 alpha)
Worked: 2.83.20
Caused by
1aa54d4921
Physics force field affect is inversely proportional to the rigid body world solver substeps per frame. For example if you increase steps per frame by x10, the force effect is x1/10. Thus to maintain the same force result you have to match any changes to the substeps per frame to changes to the factor on force strength.
This issue doesn't exist with 2.83.20 and I noticed that this older version had 'steps per second' which has since changed to 'substeps per frame', so I suspect there might be some issue related to this change.
See attached '2022-05-19 force substep dependence.blend'. 2022-05-19 force substep dependence.blend
Alternatively the issue is easy to recreate...
Added subscriber: @badbunny_uk
Added subscriber: @lichtwerk
Can confirm, will check
Added subscribers: @JacquesLucke, @ZedDB, @brecht
Caused by
1aa54d4921
I will dare setting this to High prio since we know what caused this and it basically makes using substeps in combination with forcefields useless.
(but prio could be lowered again since rigidbodies lack a dev atm)
CC @ZedDB
CC @JacquesLucke
CC @brecht
Physics force field strength affect varies inversely proportion to physics substeps per frameto Regression: Physics force field strength affect varies inversely proportion to physics substeps per frameIt seems like the issue is that the beginning of
btDiscreteDynamicsWorld::stepSimulation
computes that there should only be one subset.clampedSimulationSteps
always ends up being 1 for me. I don't really know why that is yet. The meaning of thetimeStep
andfixedTimeStep
input to the function is not clear to me.This might have been broken by the change to the parameters that are passed to
RB_dworld_step_simulation
.Added subscriber: @sreich
CC @sreich
Added subscriber: @LukasTonne
The problem here is that the force value of the RigidBody is temporary and gets reset to zero after each Bullet simulation step. The first (Blender) substep has the correct value set by
rigidbody_update_simulation
(called outside the substep loop), but after that the external force on the body is zero and no further impulse is added.The smaller substep number makes a larger timestep which increases the impulse added in the first timestep. In the remaining substeps the body just coasts at a constant velocity and no further impulse is added. If the force was set correctly in each substep we could expect the smaller per-step impulse to be compensated by the larger step number and the overall impulse over the whole timestep to be the same.
So the solution should be to call
for each of the substeps to ensure correct force values.The arguments to the Bullet step function are actually correct (stackoverflow explanation ):
timeStep
: Overall actual time step in seconds. Physical time sincestepSimulation
was last called.fixedTimeStep
/timeSubStep
(C++ vs C-api, same thing): A fixed time step (typically 1/60 second) which is the actual step used by Bullet internally and help stabilize simulation. Variable timestep is usually not recommended because it causes stability issues in many cases, but since Blender already has a fixed, frame-based timestep this doesn't matter.maxSubSteps
: If > 0 then it will perform fixed timesteps adding up to thetimeStep
count (min(maxSubSteps, (int)(timeStep / fixedTimeStep))
), and the remainder is filled by an extra step and then interpolating to the fraction of time remaining. We just use 0 for a "variable" timestep, which is actually just fixed to the Blender substep.This issue was referenced by
f4d8382c86
