Crash in sculpting when Ctrl R and Shift R grid doesn't work #98347
Closed
opened 2022-05-24 06:00:02 +02:00 by Kendall · 4 comments
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.77
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: f1cca30557
Worked: (2.8)
In Sculpt mode, I can't bring up the grid when I Shift R and I Crash when I Ctrl R.
My workspace is set for 3D Printing, So I units is set for Millimeters and unit scale is set at .001
Add mesh
cube
size 250 mm
Subdivide Modifier 3 levels
Sculpt mode
Shift-R (no Grid just square)
Ctrl-R (Crash)
Did a Factory default settings and did the same thing as above except used the default cube at 2 mm. the Shift-R works and the Ctrl-R works without crashing. when I size up the cube to 250 mm it starts the problem again.
BooGzB3.0.blend
**System Information** Operating system: Windows-10-10.0.19044-SP0 64 Bits Graphics card: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.77 **Blender Version** Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: `f1cca30557` Worked: (2.8) **Short description of error** [Please fill out a short description of the error here] In Sculpt mode, I can't bring up the grid when I Shift R and I Crash when I Ctrl R. **Exact steps for others to reproduce the error** My workspace is set for 3D Printing, So I units is set for Millimeters and unit scale is set at .001 >Add mesh >cube >size 250 mm >Subdivide Modifier 3 levels >Sculpt mode >Shift-R (no Grid just square) >Ctrl-R (Crash) ----------------------- Did a Factory default settings and did the same thing as above except used the default cube at 2 mm. the Shift-R works and the Ctrl-R works without crashing. when I size up the cube to 250 mm it starts the problem again. [Based on the default startup or an attached .blend file (as simple as possible)] [BooGzB3.0.blend](https://archive.blender.org/developer/F13102034/BooGzB3.0.blend) ![error.png](https://archive.blender.org/developer/F13102036/error.png)
Author
Added subscriber: @Kendall-3
Member
Added subscriber: @lichtwerk
Member
You are likely running out of memory, same as reported here #77868 (Remesh Voxel Size can be much to small by default (leading to crashes). 'Edit Voxel Size' operator can have wrong range)
  • you are not seeing the grid because you have so many subdivisions on the grid that these just dont display anymore, blender automatically fades then (210mm / 0.085mm = ~2470 subdivisions in one axis)
  • remeshing with so many subdivisions would mean roughly 15billion voxels
It is also less then ideal that the grid is somewhat not matching the dimensions to start with, but that is also discussed in #77868 (Remesh Voxel Size can be much to small by default (leading to crashes). 'Edit Voxel Size' operator can have wrong range), will merge reports.
You are likely running out of memory, same as reported here #77868 (Remesh Voxel Size can be much to small by default (leading to crashes). 'Edit Voxel Size' operator can have wrong range) - you are not seeing the grid because you have so many subdivisions on the grid that these just dont display anymore, blender automatically fades then (210mm / 0.085mm = ~2470 subdivisions in one axis) - remeshing with so many subdivisions would mean roughly 15billion voxels It is also less then ideal that the grid is somewhat not matching the dimensions to start with, but that is also discussed in #77868 (Remesh Voxel Size can be much to small by default (leading to crashes). 'Edit Voxel Size' operator can have wrong range), will merge reports.
Member
Closed as duplicate of #77868
2 Participants
Reference: blender/blender#98347
