Line Art: Crash when switching to editmode in current master #98355
Closed
opened 2022-05-24 19:53:26 +02:00 by Martijn Versteegh · 33 comments
Operating system: Linux-5.4.0-110-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.129.06
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-05-23 06:16, hash: f93b237194
Worked: 3.1
  • Open the attached .blend
  • select the 'voorklep' object
  • switch to edit mode
    crash
crash.blend
Caused by 03aba8046e
**System Information** Operating system: Linux-5.4.0-110-generic-x86_64-with-glibc2.31 64 Bits Graphics card: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.129.06 **Blender Version** Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-05-23 06:16, hash: `f93b237194` Worked: 3.1 **Short description of error** Crash when switching to editmode in current master **Exact steps for others to reproduce the error** - Open the attached .blend - select the 'voorklep' object - switch to edit mode crash [crash.blend](https://archive.blender.org/developer/F13103311/crash.blend) Caused by 03aba8046e
Author
Member
Added subscriber: @Baardaap
Added subscriber: @mano-wii
Not replicable on:
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.14802 Core Profile Context 22.2.3 30.0.14029.5006
Tested on:
version: 3.3.0 Alpha, branch: master, commit date: 2022-05-22 18:26, hash: d095fcd6b4
Can you try run ./blender --debug-gpu > gpu_debug_log.txt from the command line, trigger the bug, and attach the resulting file here.
https://docs.blender.org/manual/en/latest/advanced/command_line/launch/linux.html
Most likely it will contain more information about the error.
Not replicable on: **Operating system:** Windows-10-10.0.22000-SP0 64 Bits **Graphics card:** Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.14802 Core Profile Context 22.2.3 30.0.14029.5006 Tested on: **version:** 3.3.0 Alpha, branch: master, commit date: 2022-05-22 18:26, hash: `d095fcd6b4` Can you try run `./blender --debug-gpu > gpu_debug_log.txt` from the command line, trigger the bug, and attach the resulting file here. https://docs.blender.org/manual/en/latest/advanced/command_line/launch/linux.html Most likely it will contain more information about the error.
Added subscriber: @MDe
Not replicable on:
OS: Windows 11 64bit
GC: NVidia GTX 980 Ti
Tested on: version: 3.3.0 Alpha, branch: master, commit date: 2022-05-23 21:28, hash: c968dae054, type: release
build date: 2022-05-24, 00:06:24
Not replicable on: OS: Windows 11 64bit GC: NVidia GTX 980 Ti Tested on: version: 3.3.0 Alpha, branch: master, commit date: 2022-05-23 21:28, hash: c968dae05441, type: release build date: 2022-05-24, 00:06:24
Author
Member
I'm currently bisecting it... hope to add the offending commit later this evening
Author
Member
I don't think it's a gpu bug. I see a mesh with a bogus number of verts.
Author
Member
The offending commit is: https://developer.blender.org/rB03aba8046e07d956e43073502383579b7dfbb284
Author
Member
Added subscriber: @ChengduLittleA
Richard Antalik changed title from Crash when switching to editmode in current master to Line Art: Crash when switching to editmode in current master 2022-05-25 01:13:24 +02:00
Added subscriber: @iss
Can't reproduce either, but edited report to reflect likely cause
YimingWu self-assigned this 2022-05-25 02:49:05 +02:00
Member
Member
Because of the depsgraph usage that we found out to be "incorrecct" a few days ago, I'd assume this is a known case where a workable fix is done with D14997 (pending review).
Because of the depsgraph usage that we found out to be "incorrecct" a few days ago, I'd assume this is a known case where a workable fix is done with [D14997](https://archive.blender.org/developer/D14997) (pending review).
Member
Member
Cannot repro either. I think it's fair to raise the priority if culprit commit is known (Feel free to revert the priority)
Operating system : Windows-10-10.0.18362-SP0 64 Bits
Graphics card : AMD Radeon(TM) 535 ATI Technologies .```
Cannot repro either. I think it's fair to raise the priority if culprit commit is known (Feel free to revert the priority) ```System Information Operating system : Windows-10-10.0.18362-SP0 64 Bits Graphics card : AMD Radeon(TM) 535 ATI Technologies .```
Member
I think it's fine for high priority, we just need someone who's familiar to review [D14997](https://archive.blender.org/developer/D14997) :)
I think it's fine for high priority, we just need someone who's familiar to review `[D14997](https://archive.blender.org/developer/D14997)` :)
Author
Member
With nobody able to reproduce it smells like a threading/locking thing... I'll see if I can investigate a bit more.
Author
Member
Hm. It happens in my own build, but not in the daily ;-( so it must be some library problem in my own build maybe? But as the daily runs fine it's probably better to archive this bugreport.
Added subscriber: @deadpin
I can crash here - ASAN seems to report at least 2 types of error.
report1.txt
report2.txt
I can crash here - ASAN seems to report at least 2 types of error. [report1.txt](https://archive.blender.org/developer/F13104036/report1.txt) [report2.txt](https://archive.blender.org/developer/F13104037/report2.txt)
Author
Member
In your own build? or the daily from b.org?
And if your own build do you happen to be on ubuntu 20.04 as well?
> In #98355#1363956, @deadpin wrote: > I can crash here - ASAN seems to report at least 2 types of error. In your own build? or the daily from b.org? And if your own build do you happen to be on ubuntu 20.04 as well?
Author
Member
Oh no, I see in the report. Windows. That makes it a real thing after all I think. Especially since your crash is in the same spot as mine. I'll upload my crashlog as well.
Author
Member
[crash.crash.txt](https://archive.blender.org/developer/F13104073/crash.crash.txt)
Author
Member
stacktrace
#0  0x000000000413a061 in blender::vec_base<float, 3>::vec_base(float const*) (this=0x7fffcd5b8fac, ptr=0x5fffffff0) at /home/martijn/progs/blender-git/blender/source/blender/blenlib/BLI_math_vec_types.hh:200
        i = 0
#1  0x00000000041364d8 in operator()(blender::IndexRange, Result const&) const (__closure=0x7fffcfd13868, range=..., init=...) at /home/martijn/progs/blender-git/blender/source/blender/blenkernel/intern/mesh.cc:1660
        i = 1610612735
        __for_range = @0x7fffcd5b8f60: {start_ = 1610612735, size_ = 4194304, static s_current_array_size = {<std::__atomic_base<long>> = {static _S_alignment = 8, _M_i = 1000}, static is_always_lock_free = true}, static s_current_array = {_M_b = {_M_p = 0x7fffcc269008}, static is_always_lock_free = <optimized out>}}
        __for_begin = {current_ = 1610612735}
        __for_end = {current_ = 1614807039}
        result = {min = {<blender::vec_struct_base<float, 3>> = {x = 3.40282347e+38, y = 3.40282347e+38, z = 3.40282347e+38}, static type_length = <optimized out>}, max = {<blender::vec_struct_base<float, 3>> = {x = -3.40282347e+38, y = -3.40282347e+38, z = -3.40282347e+38}, static type_length = <optimized out>}}
        me = @0x7fffcfd13858: 0x7fffcee17808
        minmax = {min = {<blender::vec_struct_base<float, 3>> = {x = -nan(0x7fffff), y = -nan(0x7fffff), z = -230233088}, static type_length = <optimized out>}, max = {<blender::vec_struct_base<float, 3>> = {x = 3.68934859e+19, y = 3.68934859e+19, z = 0}, static type_length = <optimized out>}}
#2  0x0000000004138660 in operator()(tbb::blocked_range<long> const&, Result const&) const (this=0x7fffcfd137e8, subrange=..., ident=...) at /home/martijn/progs/blender-git/blender/source/blender/blenlib/BLI_task.hh:85
        function = @0x7fffcfd13868: {__me = @0x7fffcfd13858}
- 3  0x000000000413942e in tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::operator()(tbb::blocked_range<long> &) (this=0x7fffc1eca758, range=...) at /home/martijn/progs/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/parallel_reduce.h:325
- 4  0x00000000041392e7 in tbb::interface9::internal::start_reduce<tbb::blocked_range<long int>, tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >, const tbb::auto_partitioner>::run_body(tbb::blocked_range<long> &) (this=0x7fffd1a8c440, r=...) at /home/martijn/progs/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/parallel_reduce.h:150
#5  0x0000000004139111 in tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_reduce<tbb::blocked_range<long int>, tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >, const tbb::auto_partitioner>, tbb::blocked_range<long int> >(tbb::interface9::internal::start_reduce<tbb::blocked_range<long int>, tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >, const tbb::auto_partitioner> &, tbb::blocked_range<long> &) (this=0x7fffd1a8c468, start=..., range=...) at /home/martijn/progs/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/partitioner.h:438
        range_pool = {my_head = 4 '\004', my_tail = 0 '\000', my_size = 5 '\005', my_depth = "\001\002\003\004\004\350b ", my_pool = {array = {{member = {member = {1677721599, 0}}}, {member = {member = {1644167167, 0}}}, {member = {member = {1024, 0}}}, {member = {member = {1644167167, 0}}}, {member = {member = {1627389951, 0}}}, {member = {member = {1024, 0}}}, {member = {member = {1627389951, 0}}}, {member = {member = {1619001343, 0}}}, {member = {member = {1024, 0}}}, {member = {member = {1619001343, 0}}}, {member = {member = {1614807039, 0}}}, {member = {member = {1024, 0}}}, {member = {member = {1614807039, 0}}}, {member = {member = {1610612735, 0}}}, {member = {member = {1024, 0}}}, {member = {member = {3517498448, 32767}}}, {member = {member = {3445330320, 32767}}}, {member = {member = {68396426, 0}}}, {member = {member = {3445330423, 32767}}}, {member = {member = {3517498448, 32767}}}, {member = {member = {3424671040, 32767}}}, {member = {member = {1024, 0}}}, {member = {member = {3445330368, 32767}}}, {member = {member = {68397371, 0}}}}}}
- 6  0x0000000004138e14 in tbb::interface9::internal::partition_type_base<tbb::interface9::internal::auto_partition_type>::execute<tbb::interface9::internal::start_reduce<tbb::blocked_range<long int>, tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >, const tbb::auto_partitioner>, tbb::blocked_range<long int> >(tbb::interface9::internal::start_reduce<tbb::blocked_range<long int>, tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >, const tbb::auto_partitioner> &, tbb::blocked_range<long> &) (this=0x7fffd1a8c468, start=..., range=...) at /home/martijn/progs/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/partitioner.h:256
- 7  0x0000000004138c05 in tbb::interface9::internal::start_reduce<tbb::blocked_range<long int>, tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >, const tbb::auto_partitioner>::execute(void) (this=0x7fffd1a8c440) at /home/martijn/progs/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/parallel_reduce.h:190
- 8  0x0000000004b06c15 in tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) ()
- 9  0x0000000004b06ecb in tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) ()
- 10 0x0000000004af3f27 in tbb::internal::arena::process(tbb::internal::generic_scheduler&) ()
- 11 0x0000000004b00900 in tbb::internal::market::process(rml::job&) ()
- 12 0x0000000004b0293c in tbb::internal::rml::private_worker::run() ()
- 13 0x0000000004b02b39 in tbb::internal::rml::private_worker::thread_routine(void*) ()
#14 0x00007ffff7f3e609 in start_thread (arg=<optimized out>) at pthread_create.c:477
        ret = <optimized out>
        pd = <optimized out>
        unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140736639006464, -315144192356607752, 140736670175806, 140736670175807, 140736670176000, 140736638719104, 315243942294493432, 315126496763877624}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
        not_first_call = 0
#15 0x00007ffff78c7133 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
stacktrace ``` #0 0x000000000413a061 in blender::vec_base<float, 3>::vec_base(float const*) (this=0x7fffcd5b8fac, ptr=0x5fffffff0) at /home/martijn/progs/blender-git/blender/source/blender/blenlib/BLI_math_vec_types.hh:200 i = 0 #1 0x00000000041364d8 in operator()(blender::IndexRange, Result const&) const (__closure=0x7fffcfd13868, range=..., init=...) at /home/martijn/progs/blender-git/blender/source/blender/blenkernel/intern/mesh.cc:1660 i = 1610612735 __for_range = @0x7fffcd5b8f60: {start_ = 1610612735, size_ = 4194304, static s_current_array_size = {<std::__atomic_base<long>> = {static _S_alignment = 8, _M_i = 1000}, static is_always_lock_free = true}, static s_current_array = {_M_b = {_M_p = 0x7fffcc269008}, static is_always_lock_free = <optimized out>}} __for_begin = {current_ = 1610612735} __for_end = {current_ = 1614807039} result = {min = {<blender::vec_struct_base<float, 3>> = {x = 3.40282347e+38, y = 3.40282347e+38, z = 3.40282347e+38}, static type_length = <optimized out>}, max = {<blender::vec_struct_base<float, 3>> = {x = -3.40282347e+38, y = -3.40282347e+38, z = -3.40282347e+38}, static type_length = <optimized out>}} me = @0x7fffcfd13858: 0x7fffcee17808 minmax = {min = {<blender::vec_struct_base<float, 3>> = {x = -nan(0x7fffff), y = -nan(0x7fffff), z = -230233088}, static type_length = <optimized out>}, max = {<blender::vec_struct_base<float, 3>> = {x = 3.68934859e+19, y = 3.68934859e+19, z = 0}, static type_length = <optimized out>}} #2 0x0000000004138660 in operator()(tbb::blocked_range<long> const&, Result const&) const (this=0x7fffcfd137e8, subrange=..., ident=...) at /home/martijn/progs/blender-git/blender/source/blender/blenlib/BLI_task.hh:85 function = @0x7fffcfd13868: {__me = @0x7fffcfd13858} - 3 0x000000000413942e in tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::operator()(tbb::blocked_range<long> &) (this=0x7fffc1eca758, range=...) at /home/martijn/progs/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/parallel_reduce.h:325 - 4 0x00000000041392e7 in tbb::interface9::internal::start_reduce<tbb::blocked_range<long int>, tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >, const tbb::auto_partitioner>::run_body(tbb::blocked_range<long> &) (this=0x7fffd1a8c440, r=...) at /home/martijn/progs/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/parallel_reduce.h:150 #5 0x0000000004139111 in tbb::interface9::internal::dynamic_grainsize_mode<tbb::interface9::internal::adaptive_mode<tbb::interface9::internal::auto_partition_type> >::work_balance<tbb::interface9::internal::start_reduce<tbb::blocked_range<long int>, tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >, const tbb::auto_partitioner>, tbb::blocked_range<long int> >(tbb::interface9::internal::start_reduce<tbb::blocked_range<long int>, tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >, const tbb::auto_partitioner> &, tbb::blocked_range<long> &) (this=0x7fffd1a8c468, start=..., range=...) at /home/martijn/progs/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/partitioner.h:438 range_pool = {my_head = 4 '\004', my_tail = 0 '\000', my_size = 5 '\005', my_depth = "\001\002\003\004\004\350b ", my_pool = {array = {{member = {member = {1677721599, 0}}}, {member = {member = {1644167167, 0}}}, {member = {member = {1024, 0}}}, {member = {member = {1644167167, 0}}}, {member = {member = {1627389951, 0}}}, {member = {member = {1024, 0}}}, {member = {member = {1627389951, 0}}}, {member = {member = {1619001343, 0}}}, {member = {member = {1024, 0}}}, {member = {member = {1619001343, 0}}}, {member = {member = {1614807039, 0}}}, {member = {member = {1024, 0}}}, {member = {member = {1614807039, 0}}}, {member = {member = {1610612735, 0}}}, {member = {member = {1024, 0}}}, {member = {member = {3517498448, 32767}}}, {member = {member = {3445330320, 32767}}}, {member = {member = {68396426, 0}}}, {member = {member = {3445330423, 32767}}}, {member = {member = {3517498448, 32767}}}, {member = {member = {3424671040, 32767}}}, {member = {member = {1024, 0}}}, {member = {member = {3445330368, 32767}}}, {member = {member = {68397371, 0}}}}}} - 6 0x0000000004138e14 in tbb::interface9::internal::partition_type_base<tbb::interface9::internal::auto_partition_type>::execute<tbb::interface9::internal::start_reduce<tbb::blocked_range<long int>, tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >, const tbb::auto_partitioner>, tbb::blocked_range<long int> >(tbb::interface9::internal::start_reduce<tbb::blocked_range<long int>, tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >, const tbb::auto_partitioner> &, tbb::blocked_range<long> &) (this=0x7fffd1a8c468, start=..., range=...) at /home/martijn/progs/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/partitioner.h:256 - 7 0x0000000004138c05 in tbb::interface9::internal::start_reduce<tbb::blocked_range<long int>, tbb::internal::lambda_reduce_body<tbb::blocked_range<long int>, BKE_mesh_minmax(const Mesh*, float*, float*)::Result, blender::threading::parallel_reduce<BKE_mesh_minmax(const Mesh*, float*, float*)::Result, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(blender::IndexRange, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >::<lambda(const tbb::blocked_range<long int>&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)>, BKE_mesh_minmax(const Mesh*, float*, float*)::<lambda(const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&, const BKE_mesh_minmax(const Mesh*, float*, float*)::Result&)> >, const tbb::auto_partitioner>::execute(void) (this=0x7fffd1a8c440) at /home/martijn/progs/blender-git/lib/linux_centos7_x86_64/tbb/include/tbb/parallel_reduce.h:190 - 8 0x0000000004b06c15 in tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::process_bypass_loop(tbb::internal::context_guard_helper<false>&, tbb::task*, long) () - 9 0x0000000004b06ecb in tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) () - 10 0x0000000004af3f27 in tbb::internal::arena::process(tbb::internal::generic_scheduler&) () - 11 0x0000000004b00900 in tbb::internal::market::process(rml::job&) () - 12 0x0000000004b0293c in tbb::internal::rml::private_worker::run() () - 13 0x0000000004b02b39 in tbb::internal::rml::private_worker::thread_routine(void*) () #14 0x00007ffff7f3e609 in start_thread (arg=<optimized out>) at pthread_create.c:477 ret = <optimized out> pd = <optimized out> unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140736639006464, -315144192356607752, 140736670175806, 140736670175807, 140736670176000, 140736638719104, 315243942294493432, 315126496763877624}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}} not_first_call = 0 #15 0x00007ffff78c7133 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95 ```
Member
Added subscriber: @lichtwerk
Member
FYI: got a similar thin in #98359 (Regression: Crash switching to scene with LineArt).
That one I can reproduce (whereas this report I cant)
FYI: got a similar thin in #98359 (Regression: Crash switching to scene with LineArt). That one I can reproduce (whereas this report I cant)
Member
To me it looks like an access conflict. Let's see D14997
To me it looks like an access conflict. Let's see [D14997](https://archive.blender.org/developer/D14997)
Author
Member
Sadly this doesn't help. With this patch applied it even crashed once on loading the crash.blend file. next time it did load, but still crashed when switching to edit mode.
> In #98355#1364018, @ChengduLittleA wrote: > To me it looks like an access conflict. Let's see [D14997](https://archive.blender.org/developer/D14997) Sadly this doesn't help. With this patch applied it even crashed once on loading the crash.blend file. next time it did load, but still crashed when switching to edit mode.
Author
Member
https://developer.blender.org/D15022 fixes it
This issue was referenced by ef59c8295f
This issue was referenced by ef59c8295f0e04630a0cebae3bd4552d50cae2ba
Member
9 Participants
Reference: blender/blender#98355
