Select next active fails in some cases (default cylinder, cube) #98384
2 Participants
Reference: blender/blender#98384
Graphics card: Quadro K2100M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 411.63
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash:
cc66d1020c
When adding object: circle or cylinder, when selecting vertices, it does not select the next vertex at command: shif + ctrl + (+).
if I select several vertices manually and give the command: shift + ctrl + (-) deselect, it works perfectly.
any other option works, works well with other objects, sphere, monkey sesame, the circle object works if you select two consecutive vertices, if you select one vertex yes one no, it no longer works. .]
2022-05-24 19-58-17.mp4
Added subscriber: @SebastianFlorin
25.05.2022 7.30 PM London time zone.
I reinstalled blender 3.1.2 but it still doesn't work. I also installed 3.3.0 alpha. they don't work, they have the same bug.
Thanks for the report. I can confirm.
Maybe same as in #73202 (Edit-Mesh "Select Next Active" doesn't handle a wire edge loop (vertex mode))
Need to edit other report if anyone is merging this report
Bug select next active. v.3.1.2 & 3.1.1to Select next active fails in some cases (default cylinder, cube)
